Evo-R Adjustable Endlinks Installed
Old Apr 17, 2008 | 06:51 PM
kinchu007's Avatar
Thumbs up Evo-R Adjustable Endlinks Installed
Just took some pics of the Evo-R Adjustable Endlinks installed...I like the way it drives a lot...I'm sure the corner-weighting had a lot to do with it, but the rear end is a lot more planted...no more squirmy-ness...it tends to teeter (a-la M3) now instead of sweeping (a-la stock RX-8).
My thanks to J for the endlinks and the support!
Enjoy the pics...
(front)
Attached Thumbnails Evo-R Adjustable Endlinks Installed-100_4264-medium-.jpg   Evo-R Adjustable Endlinks Installed-100_4266-medium-.jpg   Evo-R Adjustable Endlinks Installed-100_4287-medium-.jpg   Evo-R Adjustable Endlinks Installed-100_4272-medium-.jpg
Old Apr 17, 2008 | 06:53 PM
kinchu007's Avatar
(rear)
Attached Thumbnails Evo-R Adjustable Endlinks Installed-100_4278-medium-.jpg   Evo-R Adjustable Endlinks Installed-100_4281-medium-.jpg   Evo-R Adjustable Endlinks Installed-100_4282-medium-.jpg   Evo-R Adjustable Endlinks Installed-100_4284-medium-.jpg   Evo-R Adjustable Endlinks Installed-100_4286-medium-.jpg
Old Apr 17, 2008 | 07:49 PM
SouthFL's Avatar
Very nice. Those are Autoexe, correct?
Old Apr 17, 2008 | 08:02 PM
kinchu007's Avatar
Almost...they're Evo-R.
Details for the difference are here: https://www.rx8club.com/australia-new-zealand-forum-37/autoexe-adjustable-endlink-127842/
Old Apr 23, 2008 | 05:39 AM
bigireland's Avatar
Man, We Ain't Found Sh*t!
nice..
Old Apr 23, 2008 | 05:52 AM
VarneyMazda's Avatar
Northeast Pimpin'
I'm not sure I would feel safe using knockoff suspension components, but that's just me
Old Apr 23, 2008 | 07:03 AM
SouthFL's Avatar
^ It's a turnbuckle with two ball joints with threaded rod. You can piece it together out of hardware and it will do the job. As long as the ball joint is decent and the hardware is high grade, you can't go wrong.
Old Apr 23, 2008 | 07:09 AM
r0tor's Avatar
not to mention it seems your getting the same stuff for literally 1/2 the price... silly overpriced JDM parts
Old Apr 23, 2008 | 09:28 AM
kinchu007's Avatar
From all my reading I agree with SouthFL...when it comes to endlinks it's all about the ball joints...and from looking at pics of the Evo-R ones I'm convinced they're at least as good as stock...heim joints would have been better, but I hear people wear them out on the street too quickly and they're just a nuissance.
Originally Posted by fd3s777
Old Apr 27, 2008 | 09:14 PM
fd3s777's Avatar
www.EVO-R.Net
Looks great! Had them on my 8. Handles great at coners!
Old Apr 27, 2008 | 09:47 PM
SouthFL's Avatar
Kinchu, does the rear endlink shorten enough to equal the rear OEM link in length (about 8.5cm centerline of threaded rod to centerline of threaded rod)?
Old Apr 27, 2008 | 09:57 PM
x2.
jay measurements? interested in splitting shipping?
Old Apr 27, 2008 | 10:07 PM
jay,
pm.
Old Apr 28, 2008 | 07:15 AM
fd3s777's Avatar
www.EVO-R.Net
Here is the max length of the rear links 11.5 cm
Old Apr 28, 2008 | 07:18 AM
fd3s777's Avatar
www.EVO-R.Net
Shortest 9.5 CM
Old Apr 28, 2008 | 07:19 AM
fd3s777's Avatar
www.EVO-R.Net
Originally Posted by swoope
jay,
pm.
PMed. Nice to hear from you again!
Old Apr 28, 2008 | 07:27 AM
SouthFL's Avatar
Shortest 9.5 CM
Centerline of rod to centerline of rod seems shorter than 9.5cm in that pic.
The Centerline measurement is what's key, as that's what determines the articulated length.
Could you please clarify? Only reason why I ask is because I just tried a set of Whiteline adj. endlinks and the rear set wouldn't shorten enough to match the length of the OEM endlink.
Old Apr 28, 2008 | 08:17 AM
fd3s777's Avatar
www.EVO-R.Net
from this photo below it is more than 8.5 in the center. Cuz I took photo above the endlink and ruler is below photo seems shorter measurement.
Old Apr 28, 2008 | 08:26 AM
SouthFL's Avatar
Edit: I think, simply, the wrong pic was attached. Perhaps you were referring to the shortened pic? This is getting confusing rather quickly. I just need a real measurement, lol. Thanks.
Old Apr 28, 2008 | 06:47 PM
the rears are short enough, but the only way to get it this way is that one end has to be unbolted and removed from it's mounting hole to make the adjustment, note that it's one male and one female part screwed together, not two males or two females joined by a single mating turnbuckle counterpart
none of the turnbuckle style ends will be short enough using off the shelf parts, they have to be cut shorter at a minimum
Old Apr 28, 2008 | 07:27 PM
Nemesis8's Avatar
Bigus Rotus
Knockoff?
Old Apr 29, 2008 | 05:04 AM
fd3s777's Avatar
www.EVO-R.Net
Here is measurement from center joint.
Longest
Shorest
Old Apr 29, 2008 | 06:28 AM
Derex'8's Avatar
ReDuX
What is the length for the OEM front endlink?
Old Apr 29, 2008 | 07:02 AM
SouthFL's Avatar
Longest
Shorest
thanks.
Old Jun 4, 2008 | 10:20 PM
fd3s777's Avatar
www.EVO-R.Net
In stock.
