Survey: Blown engines w/turbo
Old Apr 15, 2008 | 11:50 PM
SlideWayz's Avatar
RX-8 = Japanese MG
Question Survey: Blown engines w/turbo
For those sorry sods like me who have grenaded a Renesis; it may prove helpful to see if there's a pattern emerging with the blown engines.
Here's the questions (please add more useful questions if you can think of any):
1. Did you break an Apex seal on the front rotor or rear rotor?
2. If not an Apex seal, did you break a side seal? If so, which one?
3. What year was your engine manufactured?
4. Which kit did you have installed (or was it a custom)?
5. How many miles did you have on the engine before you installed the turbo?
6. How many miles had you put on the turbocharged engine before it popped?
7. What wheel horsepower were you making?
8. What were the conditions under which the engine blew (were you getting on it, cruising, what RPM, etc.)?
Old Apr 17, 2008 | 03:39 AM
usmc320's Avatar
What are your answers to those questions?
Old Apr 17, 2008 | 11:47 AM
SlideWayz's Avatar
RX-8 = Japanese MG
I've blown 2 engines, the second time was a rebuild of the first engine.
Rear rotor both times
Apex seal
2004
GReddy + bigger injectors, Xede, & Racing Beat OMP mod
4k, 0k (rebuilt w/turbo)
3.5k, 12k
#1: part throttle at 25 mph
#2: WOT at 7500 rpm in 3rd gear
Old Apr 17, 2008 | 11:52 AM
Red Devil's Avatar
Do you know your ignition timing for both incidents, and also your AFRs?
Also curious as was your tuning modified between the first and second engine...and if so, how?
Old Apr 17, 2008 | 01:19 PM
rotorocks's Avatar
RotoRocks Powered
Rear rotor.
It was an Apex.
2005
Custom. With T70 turbocharger at the time of failure.
@ 17K put on nitrous.
@ 20K dumped the nitrous and put on the turbo
24K with the turbo and 3K with Nitrous.
Total 27K with FI.
Had to be over 300 @12 PSI
800 rpm, Idling. at 12.8:1 -13.5:1 AF, But it must have detonated and craked the seal before because I just installed the new T70, and it most likely had a ping at the 6200 RPM as the APV opened and it went lean.
It is just that it the seal completely broke later.
Old Apr 17, 2008 | 01:42 PM
Trekk's Avatar
Goat rider
I'm sure this never gets up dated.
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/turbo-owners-fill-out-please-121542/
but if you read it you notice most people with a blown motor blame it on tunes.
Old Apr 17, 2008 | 08:28 PM
SlideWayz's Avatar
RX-8 = Japanese MG
https://www.rx8club.com/showthread.php?t=121542
Thanks.
I'm interested only in blown engines w/turbos. 'Bad tune' is not enough information. Also, 'bad tune' is almost impossible to avoid (change in temp = change in air density = different AFR, etc.) until now with the AccessPort which will chase a tune to target maps instead of the static maps of now-obsolete standalones like the eMangle, IntX, & my Xede.
Old Apr 17, 2008 | 08:44 PM
importshowoff84's Avatar
Legend in the making
this scares me as i am going turbo on my 04 with 43K on it
Old Apr 17, 2008 | 10:25 PM
suay's Avatar
Work hard Drive Hard!
Me @
I too am installing a m a z sport stage 1 kit on my 2004 50k, 8. The shop guy recommended to "open the ports". I just went to see him and he recommended me that. I was talking with the girl in charge of the parts at m a z sport and she stated 16 PSI! The shop guy im dealing with deals with rotary engines only (hard to find) and he was astonished at the fact that I said that. He was basically saying "lets go the safe way" and "keep the PSI lower" , around 9 he thinks. He's not doing the tuning though. What do U guys think? I need some info since you guys might know, based on your engine experience.
Old Apr 17, 2008 | 11:31 PM
SlideWayz's Avatar
RX-8 = Japanese MG
My engine was ported. Didn't stop it blowing up.
16 psi? Maybe if you're running pure 104 octane, live in a perpetually cold climate, and pull so much timing that the car won't run.
Otherwise, running over 1 bar of boost will grenade your engine with utter certainty and with a quickness.
Old Apr 18, 2008 | 12:15 AM
suay's Avatar
dude
how much PSi before kaboom?! do u think it was the tuning? One more question what is the max PSI for a dailey driver. I m thinking of Two maps on the boost controller. One for an occasional daily drive (not much) and the autocross/ 1/4 mile.
thanks
Old Apr 18, 2008 | 02:14 AM
LiL BenNy's Avatar
Bubblicious? DEF.
04
greddy
25k?
10k?
275whp ish
oddly downshifting.. e-shaft broke....
Old Apr 18, 2008 | 02:56 AM
you have posted a bunch of crap. please read the first post.. and answer that stuff.
btw, you are full of crap. !
i hear that z sport stuff is wack!
Old Apr 18, 2008 | 06:07 AM
auzoom's Avatar
Hmmmmmm.........
thanks
What you want for daily depends on what sort of power you want while daily driving. I run 8psi for daily and plan to use 11 on the track.
Old Apr 18, 2008 | 08:35 AM
Red Devil's Avatar
04
greddy
25k?
10k?
275whp ish
How and where did your eccentric shaft break?
Old Apr 18, 2008 | 08:46 AM
kersh4w's Avatar
Hit & Run Magnet
im assuming inside the engine.
Old Apr 18, 2008 | 08:50 AM
Red Devil's Avatar
It's a legitimate question. E-shafts don't just break often. So which bearing went bad, etc...is interesting information.
Old Apr 18, 2008 | 10:22 AM
SlideWayz's Avatar
RX-8 = Japanese MG
PSI is not the right question. What we're all after is the highest mass airflow rate. That is, how many oxygen molecules can you get in the combustion chamber per unit time.
All other things being equal, a bigger turbo will shove more air into the engine for a given PSI, which is good not only because you're not thrashing the turbo but also because the inlet charge is likely to be cooler too.
The downside of a bigger turbo is more lag since there's more mass to get moving. The 3071r sounds like a good fit since it spools up quite nicely yet can stuff enough air into the engine to make decent power.
thanks
Old Apr 18, 2008 | 11:34 AM
staticlag's Avatar
The Professor
If your going to be running high boost meth injection is a must.
Old Apr 18, 2008 | 03:52 PM
Mafia's Avatar
what do u consider high boost? anything 14lbs and up?
Old Apr 18, 2008 | 04:19 PM
MazdaManiac's Avatar
OK. I'll play!
Rear both times
Apex seal corner piece both times
both 2004
custom - Turbonetics T3/T4
IDK. I think 20k on the first and 15k on the second, give or take
about 25k on the first and 10k on the second
260 on the first 280+ on the second
First engine: Overheated (260°F coolant), mile+ altitude, 115°F ambient, WOT, 4th gear, +12 PSI climbing a hill in boost for more than 20 seconds.
Second: light throttle, first gear, 50°F ambient, cold engine. 21+ PSI because of undiscovered failed wastegate line.
GReddy e-manage in both cases. Tuning was not suspect - driver was, however. No way to cover either of those conditions any better other than to avoid them, which is a driver error.
Old Apr 18, 2008 | 05:05 PM
SlideWayz's Avatar
RX-8 = Japanese MG
I think almost everyone has a problem with the rear rotor popping an Apex seal?
Old Apr 18, 2008 | 05:18 PM
The rear runs the leanest and the hottest, especially on a turbo application.
Old Apr 18, 2008 | 05:56 PM
SlideWayz's Avatar
RX-8 = Japanese MG
Hottest I understand, but why leaner?
Old Apr 18, 2008 | 07:11 PM
Ughhh....so,...going turbo....should we upgrade or get new the apex seals as well?
