fioremike
11-10-2003, 04:28 PM
how much oil did you put in when you do a oil change the manual says 3.7 quarts I put in over 4 and the stick still shows a little below full?
View Full Version : oil change amount fioremike 11-10-2003, 04:28 PM how much oil did you put in when you do a oil change the manual says 3.7 quarts I put in over 4 and the stick still shows a little below full? KKMmaniac 11-11-2003, 07:20 AM Maybe stating the obvious, but be sure to use the proper procedure for making the final determination of oil level before adding more oil. (I don't think overfilling is good for it) That said, I find mine takes about 4 quarts and maybe 3 more ounces to bring the level to the "full" mark. (after draining about 1 hour, and replacing the oil filter, of course) rx8daniel 11-11-2003, 08:09 AM I almost want to say that some of us (like me) are anal and just let 'too' much drain by letting it drain longer than a dealer might. But my dealer claimed on my last oil change it took about 4 1/4 quarts. But then he did make it a tad over full even then (long story-they changed it twice in 3 days) because he estimated how much it would drain down and he didn't get it warm before checking it nor allow the 5 minutes the manual states should be given before checking. I am a bit curious about a difference in dip sticks. Mine is kinda 'bent' - very curved - when removed, although I don't have a clue if that can make a difference on the level it indicates!? KKMmaniac 11-11-2003, 02:03 PM My dipstick (I mean my car's dipstick!) is completely straight except for a sharp radius bent at the very end. (to help it find its way into the tube?) Might yours have been bent by somebody trying to remove or insert it improperly? deadrx7conv 11-11-2003, 03:42 PM Tilt the car this way, more comes out. Tilt the car that way, less comes out. Eat dinner while it drains, more comes out. Don't bother waiting for pan to stop dripping, less comes out. Drain it really hot, more comes out. Drain it cold, less comes out............ This is why we have dipsticks. |
