Loose Rotary Crest
Old Apr 5, 2008 | 02:18 AM
fatmanyee's Avatar
Loose Rotary Crest
I had put in a front air dam, and the dealership forgot to put the front rotary crest on.
They just sent me the old one. I installed it with with the old sticky tape inside.
One edge of it is slightly loose, any ideas on what I can stick in there or glue to secure it. Thanks!!!
Old Apr 5, 2008 | 02:31 AM
Silver06's Avatar
Zoom Zoom....
Use 3m double sided foam tape. (a body shop supply store - or even your local bodyshop will give you some) It comes in three thicknesses. The thin or middle one should work for you.
Clean all traces of old adhesive off both sides with solvent, and put one strip on each side of the vee, and it'll never come off.... (unless you take some dental floss to it).
Old Apr 6, 2008 | 02:17 AM
fatmanyee's Avatar
Thanks Silver06... great advice!
Old Apr 6, 2008 | 02:38 AM
Easy_E1's Avatar
Take it back and make them fix it.
Old Apr 6, 2008 | 07:33 PM
Ericok's Avatar
Rotary Wanker
Plus there are two little plastic safety clips on it too.
Old Apr 7, 2008 | 03:09 AM
fatmanyee's Avatar
thanks
Thanks everyone... got it on pretty tight now.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JCTaylor
Sep 30, 2015 07:31 PM
XianUnix
Sep 29, 2015 03:48 PM
DeltaJ802
Sep 29, 2015 01:20 PM
