goofydragon
03-30-2008, 04:00 PM
soldI have a custom subwoofer box for sale. It fits perfectly in little compartment in the trunk. It will hold a 10" woofer. It could be recut to hold a 12" woofer, but that would be a very tight fit. I had a 10" kicker and it was perfect. It is vented. It's made of 3/4" MDP with full carpeting. There is a hole to run the speaker wire thru. The wire was held in place with silicone from the inside, which made an airtight seal. sold
$80 shipped to your door. This is not a cheap flimsy box. Its very sturdy. I upgraded to another box so I dont' need this one anymore.
This is for the box only, no speaker. As you can see from pics 3and4, the box fits perfectly in the cubby hole in the trunk, and there's still about 3in of space left in the cubby hole.
OBTIQ
03-30-2008, 05:17 PM
can it be easily removed, if lets say i wanted to go autocrossing
hey hey hey... I plan on being in Galveston on the 2nd and 3rd... it would be cool to see this box... Maybe you could lower the price if I pickup?
goofydragon
03-30-2008, 10:12 PM
The box can easily be moved in and out of the truck. The measurements of the box are 6.25" x 13" x 27".
Keef, if you pick it up, I can lower the price to $60 (maybe $55 if I'm feeling friendly.) PM me.
xl2oGel2x
04-21-2008, 06:42 PM
Can the hole be cut to fit a 10" square??....probably an obvious answer..
If not how sure are you it will fit a 12" inch....might throw a 12" Compvt
Good price...most likely ill take it
goofydragon
04-21-2008, 11:13 PM
it can be cut to fit a square sub. I wouldn't recommend this box for a 12" sub as the fit would be extremley tight.
Now that you have me thinking about it, a square 10" would look really nice.
xl2oGel2x
04-22-2008, 12:52 AM
ya ima throw the new L5 on it...since i can get it for $90...
PMED
xl2oGel2x
04-22-2008, 05:16 AM
Hold on a sec. The L5 requires 6 3/16 mounting depth. The box is 6.25 deep. Is that the mounting depth or total height of the box. Cause if not the L5 might not fit if that's the total height because the wall width may be 1/2 inch or so.
Edit: nvm I'll just use a spacer if I need to
SirZyrion
04-22-2008, 10:58 AM
2nd dibs... I'm interested is xl2oGel2x changes his mind.
goofydragon
04-22-2008, 11:16 AM
pms answered. sale pending
xl2oGel2x
04-25-2008, 05:07 AM
AHAH yes its mine....awaiting arrival....if you guys were wondering I decided on the same set up with the 10" Kicker CVr.....only temp while I save up to get some serious custom work done....
