Quick OEM Spring question
Old Mar 30, 2008 | 09:16 AM
apotocki's Avatar
Anyone out there know the difference between the OEM front and rear springs - I need to be able to identify them visually.
I have a set laying around in my garage and want to label them.
Here are the differences:
One pair is slightly thicker/heavier and about an inch longer than the other - these have a purple paint dot on them
The other pair is identified by an orange-pinkish dot.
Old Mar 30, 2008 | 09:33 AM
chancejat's Avatar
Drive it like u stole it!
not sure but id guess the bigger ones are for the front....seeing as how the front end is always sits a little higher than the rear....
Old Mar 30, 2008 | 09:39 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Gonna feel mighty sill if I'm wrong(it's been too long), but I believe you are correct......thicker/longer/purple dot is front.
Old Mar 30, 2008 | 09:48 AM
apotocki's Avatar
Thanks for the quick replies.....but.....
I initially thought the same as both of you. But - when I went into the Lowering Springs DIY thread it stated for the lowering springs that the slightly longer spring was the rear!
Does anyone know for certain pertaining to the OEM springs? Maybe someone can take a quick look? I appreciate it.
Old Mar 30, 2008 | 09:56 AM
Mazurfer's Avatar
Hold on a few and I will find out for sure.
Old Mar 30, 2008 | 10:07 AM
apotocki's Avatar
Hey guys - I think I found it....the SEARCH function is great - just have to sift through many, many threads. But, here is one with provides me with the measurements and also a picture.
You were right - shorter orange-pinkish dot is the REAR!
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/what-oem-spring-heighs-perch-ids-118674/
THANKS!!!!
Old Mar 30, 2008 | 10:10 AM
Mazurfer's Avatar
Good...........at least I'm not crazy! Guess I better go label mine that are sitting in a box as well.
Billy Marcial
Mar 1, 2018 06:50 AM
Kahl
Aug 20, 2015 11:49 PM
Jazzmeson
Jul 31, 2015 01:48 AM
Jazzmeson
Jul 31, 2015 01:47 AM
cushing75
Jul 22, 2015 09:37 AM
