Another TPMS Problem
Old Mar 23, 2008 | 05:23 PM
rxracer208's Avatar
I've noticed lately my TPMS lite will come on and stay on for a while but as im driving it will go off. I've checked the tire pressure and its good. Also it normally only happens when its cold out. Can anyone help me out on this one?
Old Mar 23, 2008 | 05:53 PM
CTrx8's Avatar
space for rent
did you check the tire pressure before you started driving? is it blinking or staying solid?
Old Mar 23, 2008 | 06:30 PM
rxracer208's Avatar
I checked it before driving and it stays solid and after driving a while it goes out
Old Nov 4, 2008 | 12:52 PM
Kamen's Avatar
ShInY..Very ShInY!!
<-----BUMP...
I just yesterday am having this same exact problem, any ideas?
Thanks guys.
Old Nov 4, 2008 | 01:38 PM
Silver06's Avatar
Zoom Zoom....
The O/P never got back and said if they solved their problem......
So, a couple of shots in the dark....
When the weather is cold, and the tires are cold, I have noticed a 4psi difference from warm (driven) tire temps on my aftermarket TPMS that shows individual pressures. This has been enough to give me a warning (I have my low alarms set at 28psi) on a really cold morning.
So, you should be filling/checking your tires when stone-cold. Fill them to 33psi with a good gauge, and see if your problem goes away.
On the other hand, I think the batteries in the TPMS sensors are quoted as having a 7 year lifespan. I would not be surprised to see TPMS problems discussed soon that are the result of bad sensor batteries.
I believe that a Dealer can plug your car into their diagnostic computer and isolate a particular sensor malfunction.
Old Nov 4, 2008 | 03:52 PM
Kamen's Avatar
ShInY..Very ShInY!!
thanks, will try tomorrow morning and get back to ya on the status...makes sense tho it just started to get cold in the mornings now.
Old Nov 4, 2008 | 05:26 PM
J8635621's Avatar
Pew Pew Pew
Mine has done it before. I surmise the pressure is low due to the low temperature and then the pressure gets above 27psi or so, causing the light to go off, due to the tire heating up.
Old Nov 4, 2008 | 05:37 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Correct!
Wow.......it used to be foam on the dipstick when it got cold out.....seems like this year it will be TPMS.
Old Nov 4, 2008 | 08:48 PM
c41250n's Avatar
cause when itz cold, your tire pressure will be lower too.
as when you start driving it, the tires heat up, then the tire pressure to back to normal!
Old Nov 7, 2008 | 01:47 PM
Kamen's Avatar
ShInY..Very ShInY!!
thanks for your help on this guys, but after checking the pressure cold, and then later hot, both were fine. I took the car in to the delarer for a few warranty things to be done and it was a bad tpms sensor, they replaced it and all is good now. Again thanks for all the info!
Digitz0070
55
Jul 25, 2017 08:40 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
