TPMS Blinking After About 20 Minutes of Driving?
Old Mar 22, 2008 | 06:51 PM
GameGuy369's Avatar
Hey guys. Last week, I noticed my TPMS light starts to blink after about 20 minutes of driving, and typically after driving higher speeds (65-75MPH).
I took it in for an oil change and tire rotation/balance and mentioned it, but apparently they didnt see anything obvious. Should I be concerned and get it looked at again?
Old Mar 22, 2008 | 07:00 PM
Dive Bum's Avatar
IYAOYAS
Ummm, check the tire pressure.
Old Mar 23, 2008 | 07:00 AM
RWatters's Avatar
My guess is it's not getting a reading from one of the sensors. When I had my snow tires mounted the TPMS light would start blinking after 5-10 minutes of driving and it was because there were no TPMS sensors even mounted on the wheels.
Old Mar 23, 2008 | 07:09 AM
HCTR154's Avatar
Is your car lowered? Stock or aftermarket wheels/tires? Also, did you check the tire pressure on your tires when you saw the light blinking?
I ask because I seem to have a problem with air pressure building in my rear tires on longer trips. When I bought the car, it already had aftermarket wheels and I believe the offset is not correct causing a wear/excess friction problem.
Hope this helps.
Old Mar 23, 2008 | 11:39 AM
Go48's Avatar
The TPMS system will alert for under or over inflated tires. My guess is that when tires are warm the pressure exceeds the upper limit. Check the tire pressure with the tires completely cold--like maybe overnight--and set to 32psi.
Old Mar 23, 2008 | 12:11 PM
ZoomZoomH's Avatar
Mulligan User
the TPMS light will stay solid and beeeep if it's a tire pressure issue.
if it's flashing after about 10-20 minutes of driving it means it is having trouble communicating with one of the sensors in the wheels.
bottom line: one of your tire pressure sensors in the wheels is broken, get it replaced and you'll be fine.
Old Mar 23, 2008 | 02:43 PM
invasion08's Avatar
First check the tire pressures. If they are all 32 then get new tpms but if the pressure is low add more. The tpms will go off if there is too little pressure or too much pressure
Old Mar 25, 2008 | 08:19 PM
bxb40's Avatar
Rotary Newbie
I had the exact same thing happen on mine for 1 year - then finally a good tech did the diagnosis properly and found two TPMS units defective (lost transmission when warm). The other dealers always claimed "Issue could not be duplicated."
Old Mar 26, 2008 | 06:51 AM
Dive Bum's Avatar
IYAOYAS
It is amazing how few good techs there are out there... ones that have solid trouble shooting skills. I am glad you were able to track down the problem.
Old Mar 26, 2008 | 09:09 AM
dillsrotary's Avatar
jersey fresh
has it been really cold out? really cold weather will mess with the sensors in the tires
Old Mar 26, 2008 | 07:15 PM
ZoomZoomH's Avatar
Mulligan User
all the smart kids went into IT where they get to solve technical problems AND make a nice living
guess who's left to change your oil lol
Audio Concepts ATL
Sep 26, 2021 01:59 PM
RayBarron
Oct 19, 2015 08:08 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
Rx808BI
Aug 9, 2015 10:06 AM
harithac
Jul 25, 2015 04:21 PM
