View Full Version : I got a CEL Code PO456. Any suggestions?
BigWillieStyle
03-22-2008, 06:03 AM
I am looking for some suggestions from anyone who has received the CEL code before.
:banghead: I went and had the code read and here is what the print out said...
Definition: EVAP small leak detected.
Explanation: The ECM has detedted a large leak in the EVAP system during a system monitor test.
Problem Causes:
1. Defective, loose or missing fuel cap.
2. EVAP canister broke, hose cracked or not connected.
3. Purge or vent solenoid defective.
4. Vacuum leak at engine.
:banghead:
Again any suggestions, ideas or help would be greatly appreciated!! Thanks All!!
StealthTL
03-22-2008, 06:25 AM
You left your gas cap loose for two fill-ups.
Crank it till it clicks.
Dont worry, you are probably on an old version of the flash software for the computer - newer versions decrease the sensitivity for this alarm.
S
BigWillieStyle
03-22-2008, 04:34 PM
I didn't think it was my gas cap, because I hadn't gotten a fuel fill up in about a week. Also, the gas cap was the first thing I checked and it was tight.
Do you think I may need to get the gas cap replaced? Or do you think I should get the comp a new flash?
Thanks Guys!
VOODOO8
03-23-2008, 10:09 AM
Thanks Guys!
In the absence of any other type of guidance, starting a diagnostic loop with the cheapest thing that might need to get fixed and working your way up from there is usually a sound procedure to follow.:)
expo1
03-23-2008, 10:14 AM
Get a new gas cap, Stant part #10838. Fixes this issue almost all the time.
