View Full Version : C.E.L On
05BlueRX8
03-16-2008, 03:30 PM
I put in an intake and had no issues with my car. On saturday I installed 3 pulleys, the water pump. alternator and an alluminum underdriven crank pulley. After We put the car back together I got a C.E.L. I allready reset the ECU. Rather than flashing it's now on all the time. I am figuring it's the spark plug/spark plug wires but i wanted to see if anyone here may have an idea of anything else it could be.
http://www.theautolog.com/uploads/bluerx8/3981/600px/2005-Mazda-RX-8-3319.jpg
http://www.axcessmypics.com/photos/photo05/10/6b/9e8c4ac65ac0.jpg
chancejat
03-16-2008, 03:34 PM
take it to autozone and ask them to check it.....its free....
chickenwafer
03-16-2008, 04:04 PM
How did you "reset" the ECU?
Some of those wires look dangerously close to your belts, BTW
05BlueRX8
03-16-2008, 04:11 PM
they said it was code P300 and P301 misfire in cylinder 1
I will have my friend down here check out the wires and move them out of the way.
and i turned the car to "on" and pumped the brakes rapidly til the oil gauge moved.
chickenwafer
03-16-2008, 04:12 PM
Your eccentric shaft profile sensor needs to be reset more than likely, and then clear those misfire codes.
05BlueRX8
03-16-2008, 04:19 PM
how should i go about doing that, if you could please tell me.
chickenwafer
03-16-2008, 04:40 PM
Disconnect your battery and pull the "room" 15A fuse in the interior kick panel. Wait 5 minuets and then reconnect everything.
05BlueRX8
03-16-2008, 04:51 PM
o.k. and that should get rid of the C.E.L? Is there anything else i'll need to do?
05BlueRX8
03-16-2008, 07:00 PM
it worked!! thank you so much!
