gregs
03-16-2008, 12:15 PM
looking to mount and install my emanage ultimate i want to run the ultimate in the glove box, my question is does anyone have a picture i can use as a reference where to place the harness through the firewall? looks like the heater box is behind the glove box...pictures would help alot
thanks
greg
first-rotary04
03-16-2008, 09:22 PM
hahahah I'm in that same boat with you
don't where to mount it
Phish806
03-17-2008, 07:22 AM
If you remove the washer fluid tank and pull back the insulation on the firewall you will see where the steering would have came through on a right hand drive car. This works perfect for making a hole to pass through there, there is enough space on the inside of the firewall where you will not drill into anything and it will pass out right behind the glove box. when feeding the wires from the engine to the interior you will need to direct the wires slightly downward and you will see them emerge into your floorboard. There is a pic somewhere on the boards. I think it was in a thread for routing the power wire for an amp.
gregs
03-17-2008, 10:36 AM
thanks alot for the help!
first-rotary04
03-17-2008, 11:48 AM
so i still have to drill it ??
I thought that there was gonna be a hole already made.
am i wrong ?
staticlag
03-17-2008, 11:56 AM
am i wrong ?
yup, you have to drill it.
tdiddy
03-17-2008, 12:01 PM
I took a picture for you but forgot to upload it last night. It shows where to drill/cut the hole in the firewall. I will upload it tonight.
tdiddy
03-17-2008, 07:23 PM
As promised. Pics of where I cut the hole for my EMU harness.
gregs
03-17-2008, 08:47 PM
makes alot more sense thanks tdiddy
