View Full Version : V-Power racing(100 octane question)?
matt13b
03-14-2008, 01:23 AM
Mazda told me that there was no point using the 100 octane fuel as the ecu cannot recognise it and therefore just burns is as it would 98?? Is this true,or is there a power increase from the 100 octane fuel. Also, would this also mean that you could not put racing fuel in forn track days that is higher than 100 octane?
MACCAA
03-14-2008, 03:08 AM
Sounds about right.Very little[if any]to be gained from a NA Rotary on 100oct.
Unless you have a turbo and the ability to tune it to the higher octane fuel,you'll just be waisting your money.
Cheers
Len
takahashi
03-14-2008, 04:21 AM
Yes that is very true Len. Stock ECU is tune to 95 RON.
matt13b
03-14-2008, 04:58 AM
So there is no point putting 98 in either is that right??
auzoom
03-14-2008, 06:40 AM
I will tell you a story and you can make your own mind up.
Knightsports came to australia a while back to do ecu tuning. Taka went first with normal VPower 98. Cant remember his exact before figures but it was around 120rwkw, his after was about 125rwkw.
When it was my time, I did my before dyno and pulled 124rwkw. I was running vpower racing. My run was later in the day, it was hotter and more humid.
Mod wise we had at that time about the same thats important on a dyno and thats is basically nothing ... pod filters and intakes.
takahashi
03-14-2008, 08:04 AM
I am going to another dyno and use V Power racing in April. And see if the tune have significant gain with the V Power racing.
I prob just use V Power racing to dyno, so it won't be scientific anyway :dunno:
