TPMS light didn't turn on .. and offset ?
Old Mar 12, 2008 | 10:57 PM
romycha1's Avatar
Alright, I got bored tonight and decided to try on my new wheels. I did not put any TPMS sensors in the new wheels, so I figured the light would pop on once I started driving down the road. Well, I drove a good 7-10 miles and the light didn't come on at all. I know the light works, because it does light up when my OE wheels get a little low.
Has this happened to anyone else?
Also, my wheels are 19x9.5 all the way around with a 35 offset, with 255/35's. I'm dropped with Tanabe GF210's. I didn't think the 35 offset was too bad, but when I took the wheels back off I saw that they were rubbing on the springs a little bit.
Does anybody else use this setup?
Old Mar 13, 2008 | 08:07 AM
dytrd5's Avatar
same thing happened to me just wait until you drive about 20 miles or you hit 70MPH and it will start flashing. As far as the rubbin I don't know so can't help you there.
Old Mar 13, 2008 | 08:12 AM
Spinning Sushi's Avatar
I <3 Sushi
Mine turns on after 10 minutes of driving without the sensors installed.
Old Mar 13, 2008 | 02:19 PM
c41250n's Avatar
shouldn't rub
Old Mar 13, 2008 | 02:36 PM
sauceyI986's Avatar
sometime it will come i remember not having them installed on my last set of wheel and it would come on for a couple of weeks but some time it would come on and go off. One nite i was showing out as was burning rubber till my tires pop and it took the TPMS about 4 min to acutally come on and that was on stock tires.
Old Mar 13, 2008 | 04:02 PM
romycha1's Avatar
Originally Posted by c41250n
shouldn't rub
It does rub a little bit... It touches the lip in the fender wells on the quarter-panels when I'm turning. And I know it's touching the springs because when I took the wheels back off, a portion of the springs were clean, as if someone wiped it down.
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
rx8wankelrotary
Aug 17, 2015 10:42 AM
T_Mags
Jul 24, 2015 11:29 AM
