TheWulf
03-06-2008, 10:26 PM
Ok... I'm not by any means the best resource for this kind of thing, but I've considering setting up gauges and it's been a PITA to find a single thread that has all the information I need. I'm not the most mechanically inclined person, so I don't even really know why most people choose one gauge over another. We need a "Noob's guide to gauges" :)
I don't presume that the information below is 100% accurate, so please correct me if I'm writing BS and I'll update this post so that next time someone needs concise information they'll find it. Most of this post was mashed together from dozens of threads and other websites.
Please add to this if you feel the need to; especially installation tips and the reasons someone should choose a specific gauge.
**Don't take this as gospel until the resident experts have added their opinions :)
Ok here we go:
Mounting Options
There are 3 places we can mount gauges:
The A pillar: ]This is where gauges usually end up on most other cars. Click here for an example. (http://www.reidonly.net/GTP/pix/DSC03230.JPG) Available from Carbontrix. (http://www.carbontrix.com/store/index.php?main_page=product_info&cPath=1_14&products_id=74&zenid=a7f7a81a6af90aee1427be78a6beb664)
Above the NAV screen: Only if you don't have the NAV package, obviously. This is commonly known as the LOTEK pod. Click here for the thread on this. (http://www.rx8club.com/showthread.php?t=110937)
Ashtray/Cig lighter: This is commonly known as the Racing Beat gauge pod. Click here for the thread on this. (http://www.rx8club.com/showthread.php?t=99728) | Click here for a DIY on this. (http://www.rx8club.com/showthread.php?t=133938)
Gauge Options
Air/Fuel Ratio (AFR) Gauge
What it does: Measures the ratio of air to fuel in the combustion chamber and lets you know if you are running rich (more fuel) or lean (less fuel). A richer mix will give you more power while a leaner mix will give you more fuel economy. More info: http://en.wikipedia.org/wiki/Air-fuel_ratio
Why you want it: Keep an eye on your gas mileage, engine performance, emissions and/or the condition of your O2 sensor.
Normal reading: 10:1 (startup) 13:1 - 15:1 (normal)
Required accessories: None
Installation difficulty/tips:
Boost (EGB/MBG) Gauge
What it does: Measures the air pressure inside the manifold. More info: http://en.wikipedia.org/wiki/Boost_gauge
Why you want it: Keeping an eye on your manifold pressure ensures you won't blow your manifold or your engine under high pressure.
Normal reading: Depends on your boost application, many people advocate under 9psi
Exhaust Gas Temperature (EGT) Gauge
What it does: EGT is an indication of how hot the combustion process is and the amount of afterburning that is occurring in the exhaust manifold. EGT is also directly related to the air/fuel ratio. The richer the air/fuel ratio, the higher the EGT will be. For more info: http://bankspower.com/Tech_whyegt.cfm
Why you want it: Keeping an eye on your EGT will warn you when you're pushing your engine too hard to avoid engine damage.
Normal reading: 800F - 1200F
Required accessories: Exhaust Temp Sender
Fuel Pressure Gauge
What it does: Monitors the pressure at which your fuel pump is pumping your fuel.
Why you want it: If you've modified your fuel system, it might be a good idea to keep an eye on your fuel pressure to ensure that fuel is pumping at the right pressure.
Normal reading: 60psi
Required accessories: Fuel Pressure Sender
Oil Pressure Gauge
What it does: Measures the amount of pressure created in an engine's oil system by the oil pump. A certain amount of oil pressure is needed to circulate oil throughout the engine and to maintain adequate lubrication. Low oil pressure or loss of pressure is dangerous because it can lead to expensive engine damage. High oil pressure may indicate a blocked filter, blocked oil gallery or the wrong grade of oil. More info: http://www.international-auto.com/index.cfm?fa=ad&aid=45
Why you want it: We all know the story of the RX8 and its oil thirst. If you haven't modified your OMP and are feeding off oil from the crankcase, this is a little extra to make sure you aren't running low.
Normal reading: Varies with RPM, 15psi (idle) 65psi (max)
Required accessories: Oil Pressure Sender (Opt: Oil Filter Adapter Plate)
Oil Temperature Gauge
What it does: Measures the temperature of the oil in your crankcase. High oil temperature in excess of 240°F (115°C) will break down petroleum oils and cause oxidation, which in turn forms deposits, varnish and increases wear. Low oil temperatures will cause formation of sludge, which can block oil passages. Very low temperatures of -40°F (-40°C) will make oil too thick to flow.
Why you want it: If you're not using 5W20 and you're not sure if the oil you've chosen if right for your 8, this can be a little bit of extra help to make sure your oil is flowing properly.
Normal reading: 180F - 210F
Required accessories: Oil Temp Sender (Opt: Oil Filter Adapter Plate)
Voltmeter Gauge
What it does: This measures the voltage output of your alternator. If this drops too low, your vehicle is running off battery power -- this can be the sign of a faulty alternator or voltage regulator. If this is going too high, it could mean a bad battery that constantly needs to be recharged.
Why you want it: Helps you keep an eye on the condition of your alternator and battery; especially useful if you have an aftermarket stereo with a amplifiers (in this case, having a capacitor would really help).
Normal reading:13.6V - 14.4V
Required accessories: Nones
Water Temperature Gauge
What it does: Measures the temperature of the engine coolant. If the reading is too high, your engine could suffer severe thermal damage, rendering it a nice paperweight. Low readings should be rare, unless the car is just started, and would usually amount to a faulty sensor.
Why you want it: Keeping an eye on your water temperature lets you know when to let your car cool off to keep your engine from overheating; especially useful if you're running any sort of forced induction, aftermarket radiators or if you're playing with different types of coolant. It can also help you notice a radiator leak before it's too late.
Required accessories: Water Temp Sender
Installation difficulty/tips:G
Ok here we go:
Mounting Options
Gauge Options
Fuel Pressure Gauge
Oil Pressure Gauge
Voltmeter Gauge
