CEL not on after midpipe install :[
Old Mar 2, 2008 | 07:05 PM
Dmac710's Avatar
Question CEL not on after midpipe install :[
As the title stated i recently installed my turboxs midpipe with my turboxs cat back. And my cel did not come on at all my car is a 04 model with about 40,000 miles and my mods are a k&n drop in filter and a canzoomer piggyback and the turboxs exhaust. Could the canzoomer be causing my cel to not come on?? im so confused lol
Old Mar 2, 2008 | 07:18 PM
darnellm's Avatar
Drive it for a while
Old Mar 2, 2008 | 07:20 PM
mysql's Avatar
Doppelgänger
the car checks for several things. you need to drive the car in a few different situations before it verifies cat issue and lights up.
Old Mar 2, 2008 | 08:17 PM
Dmac710's Avatar
yea ive been driving alot to school and back which is like 20 miles a day and i have driven it in many conditions from normal to like 4th gear pulls on the highway still no light..... wat if my car is misfiring and the check engine light dont come on that would be serious
Old Mar 2, 2008 | 08:24 PM
alnielsen's Avatar
And how is this a problem?
Old Mar 2, 2008 | 08:33 PM
jones75254's Avatar
^^exactly
Old Mar 2, 2008 | 08:51 PM
Dmac710's Avatar
this could be a major problem... lets say my car could be misfiring and the check engine light wont come on... im thinking the canzoomer mite have disabled the check engine light
Old Mar 2, 2008 | 08:58 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
The CZ unit did not Disable your CEL and some users have there CEL for being Cat Less and some don't.
Old Mar 2, 2008 | 09:01 PM
Dmac710's Avatar
ok thanks for the clarification, that makes me feel better
Old Mar 2, 2008 | 09:23 PM
s13lover's Avatar
If you have a misfire the CEL will light up. The downstream O2 sensor has no affect on misfire monitoring. The only thing the downstream sensor does is monitor catalyst efficiency. When the car is in closed looped operation the ECU looks at the signal from the upstream O2 sensor to control your air/fuel ratio. The ECU then knows from that signal what the downstream sensor should be reporting if the cat is working properly. If the two signals do not correspond with one another then you will have a CEL for either catalyst system inefficiency or a voltage range issues on the downstream unit. When the ECU is running through it’s readiness monitors, the catalyst efficiency is the last thing that is checked. If you don’t meet the correct driving conditions for all of the other monitors to set, it may take a week or two for that CEL to come on. However, (I have no explanation for this) I have a friend with a Sentra SE-R Spec V that ran without cats or an O2 simulator for over a year and never had a CEL.
Old Mar 2, 2008 | 09:33 PM
Dmac710's Avatar
hmm thats some interesting information, i guess its just one of those weird things not every car gets them...
Old Mar 3, 2008 | 02:49 AM
tiltmode43's Avatar
OMGITM!
Want the CEL to show up? Run is hard...
Old Mar 3, 2008 | 08:21 AM
Dmac710's Avatar
trust me... its been ran hard
Old Mar 3, 2008 | 09:06 AM
StealthTL's Avatar
Metatron
After a certain number of 'drive-cycles' the CEL will go off, to allow new codes to be seen. It's not 'gone', it is still set in the memory as a fail, but the light is off.
S
Old Mar 3, 2008 | 10:55 AM
Dmac710's Avatar
S
thanks for the info i love this forme
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
DVerdeyen
Sep 13, 2015 11:19 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
