Airbag Light Flashes then turns Solid! HELP!
Old Feb 26, 2008 | 10:42 PM
Spinning Sushi's Avatar
I <3 Sushi
So, my airbag light just flashes and then turns solid. How do I fix this?
Here's a video of it.
http://www.youtube.com/watch?v=26u3f4B5dTI
I have tried using this method: https://www.rx8club.com/series-i-tech-garage-22/air-bag-light-came-130704/
It does not work for me. I voided my warranty long ago so please help me out.
Old Feb 26, 2008 | 11:22 PM
Check all Airbag connectors then.
no need to panic, check them one by one, is not the end of the world.
Old Feb 26, 2008 | 11:34 PM
StealthTL's Avatar
Metatron
....especially the two under the front seats, and the one behind the glovebox.
S
Old Feb 26, 2008 | 11:45 PM
I <3 Sushi
I can't seem to find the one behind the glove box. Do you guys have a picture of it?
Old Feb 26, 2008 | 11:55 PM
StealthTL's Avatar
Metatron
Drop the glove box (disconnect the damper, push in the retainers)
The wire covering is yellow. There was a recall for older cars because this connector was stretched/too short - did yours get the extension put on?
S
Old Feb 26, 2008 | 11:57 PM
I <3 Sushi
Actually, how many connectors are there total? I know there are one under each seat. I just learned of the one behind the glove box (Still can't find it). There should be more for the side curtain airbags, correct? If so, can someone enlighten me as to where these connectors are located?
BTW, I made sure the ones underneath the seats are connected and I can still replicate the flashing airbag light that turns solid.
Old Feb 26, 2008 | 11:58 PM
I <3 Sushi
S
I'm not so sure if it received the recall. My car was bought in August of 2006. Thanks for the info though, I'll go check the length of the connector right now and see if it's seated properly.
Old Feb 27, 2008 | 12:15 AM
I <3 Sushi
So, the one behind the glove box is plenty long and it's seated properly. I disconnected it and reconnected it. I'm going out for another drive to see if it comes on again (it usually comes on around after 5 minutes worth of driving).
Old Feb 27, 2008 | 01:00 AM
I <3 Sushi
Awesomeness! My airbag light does not come on anymore. Thanks guys!
I love RX8Club.com! Time for a group hug!
Old Feb 27, 2008 | 01:30 AM
HiTMaNN's Avatar
RX-8s Official Cool Guy
I know I didn't help but can I join in the hug?
Old Feb 27, 2008 | 01:34 AM
StealthTL's Avatar
Metatron
.........can I join in the hug?
Eeewww - that's kreepy!
S
Old Feb 27, 2008 | 01:37 AM
I <3 Sushi
S
What are you talking about? You're the pink one.
I <3 Sushi
Yes you can.
Old Feb 27, 2008 | 01:46 AM
Broke Back Rx8club.com ?
Old Feb 27, 2008 | 01:49 AM
I <3 Sushi
Admit it, you want in too.
Old Feb 27, 2008 | 02:01 AM
HiTMaNN's Avatar
Yes you can.
I am the Blue one he looks like the only straight shooter in that group
Old Feb 27, 2008 | 02:02 AM
I <3 Sushi
I'm the yellow one because... I'm asian.
Old Feb 27, 2008 | 02:06 AM
HiTMaNN's Avatar
IF they had a brown one that would be since they don't I am blue by default
Old Feb 27, 2008 | 04:43 PM
dozer's Avatar
on his 3rd rx8
way to go john!! so if mine ever comes on you know where all the connectors are.....this happend to my old 8, it would come on the go off...
Old Feb 27, 2008 | 04:47 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Was a good read just so if I ever do have the issue, I'll know about the one behind the glove..............and not have to go pull out the cable wiring pic/diagrams.
BTW John(Renesis SE3P)..............Still no mail arrived in either case(MO or parts)????
Old Oct 16, 2008 | 07:34 PM
coastie08's Avatar
my airbag light has been intermittently flashing on and staying on for the last 3 weeks or so, I tried the things mentioned in this post to no avail. I broke down and took it to the dealer...DTC B2691 L/F seatbelt buckle loose connector...
fyi for anyone that still has the light and is checking loose connections.
TeslaMSI
Dec 10, 2015 01:10 AM
wayloco
Sep 1, 2015 09:03 PM
mesaboogie
Aug 7, 2015 10:48 AM
Kim Jong Illest
Aug 6, 2015 02:34 PM
Jmanie9515
Jul 20, 2015 07:29 PM
