Massmaritime516
02-24-2008, 05:35 PM
This project was easy and only took a couple of days including dry-time. The first step was to remove the console. This is a pretty good copy of the maintenance manual;
http://rx8.no-ip.org/esicont/en/srvc/html/BHE091764271W01.html
This has some good pictures and helped me get started. After the first few pieces come off, the rest is relatively simple.
http://www.staticusers.net/rx-8/RX-8-iPod-Installation-iceLink.html
To remove the bezels around the air vents, just use a flathead to gently pry them off.
I sanded down all parts with 400 grit emery cloth, washed them all in soap and water, and then cleaned them with rubbing alcohol before laying down the base coats. I went with Sherwin-Williams line of auto paints and they worked well, especially for spray cans.
I put down about 3-4 light coats of color with about 15 minutes of dry-time for each. After letting them sit overnight, I hit all the pieces of trim with clear coat following the same procedure as I did for the color. Let the trim sit out for a few days afterwards or else you'll risk scratching the clear coat when reinstalling it (it stays soft for a while). Any questions, let me know.
