need some help installing my mazda speed cold air intake
Old Feb 20, 2008 | 05:43 PM
greatdagger's Avatar
k i have my car apart and putting the cold air intake but i was wondering if anybody has any pics of putting the cold air intake in stages into the car because when looking at the directions they really blow... so i was wondering if anybody know a link or has some pics tha could help me out plz...thanks in advance
Old Feb 20, 2008 | 08:28 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
I got the AEM one which is the same one as the MS (The MS Intake is a AEM one rebadged) one and the instructions that it came with were easy.
here is a DIY for the AEM
https://www.rx8club.com/showthread.p...eed+intake+diy
Old Feb 20, 2008 | 09:01 PM
hmerrittiii's Avatar
Hap
Don't have pictures but you need to take the airbox out, bumper off, lower molding off and side lights out very labor intensive. Just take it slow and follow directions
Old Feb 20, 2008 | 09:29 PM
HiTMaNN's Avatar
You are acting like you are smashing rocks with your bare hands. I am pretty much a *** when it comes to installing things and it took me an hour and a bit to install the intake.
Old Feb 20, 2008 | 09:37 PM
GuyWithRx8's Avatar
Low compression
I am installing my aem right now as well and i am wondering if i am supposed to put that bag cover thing on the filter or not
Old Feb 20, 2008 | 09:59 PM
tiltmode43's Avatar
OMGITM!
I throw it on in the rain to prevent (a lot of) condensation from forming on the MAF
In dry driving I don't think the sock really matters...
HiTMaNN's Avatar
It is your choice I did, but it is personal preference it is not so much a bag then that mesh type cover that goes over it.
Old Feb 20, 2008 | 10:01 PM
Jon316G's Avatar
Grasshopper
Yes... the sock should be installed. Its used as a barrier so that moisture doesn't collect on the filter and run up into the engine (which happened to me once).
Old Feb 20, 2008 | 10:43 PM
GuyWithRx8's Avatar
Low compression
ok i just started it up and the dsc light is flashing, will it go away by itself?
Old Feb 20, 2008 | 10:57 PM
Juice's Avatar
I made some poos
If you disconnected the battery, then the DSC needs to be reset. Turn full left then right and it should go out. Check the owners manual for more info.
Old Feb 21, 2008 | 08:01 AM
upstate_T-RX's Avatar
what do you guys suggest going with? AEM cold air intake , weapon R , Tenzo , or k&n air intake? details with please , im new to rotary engines and i love it. let me know
Old Feb 21, 2008 | 12:15 PM
HiTMaNN's Avatar
Fail.... Search is your friend
https://www.rx8club.com/showthread.p...intakes+intake
Old Feb 23, 2008 | 10:15 PM
Jon316G's Avatar
Grasshopper
I'm just having a pretty rough idle and I was just driving on the freeway and in 6th gear at about 4K rpm I can hear the popping and sounds like there's flames coming out, even when I'm pressing the gas. I guess that means there's a leak in my intake right?
I would start by resetting the KAM:
1. Turn the key to ON (do not start the engine)
2. Depress the brake pedal ~20x quickly until you see the oil pressure gauge sweep back and forth.
This will reset your sensor profiles and allow the MAF sensor to relearn itself to the new intake.
Good luck!
Not sure about the popping sounds. I haven't heard of that from an intake, more like an exhaust.
RXeckless
Aug 16, 2015 12:52 PM
Mr.Durden
Aug 12, 2015 02:21 PM
SupraG
Aug 3, 2015 10:03 PM
MrORAN6E
Jul 24, 2015 09:32 AM
AussieGray
Jul 16, 2015 03:58 AM
