creaking noise from clutch pedal
Old Feb 18, 2008 | 09:50 AM
ebala's Avatar
RX8 driver
hi guys,
i know this is very vague and general but do you guys happen to know are there any possible reasons why wld my clutch pedal suddenly start to have creaking noise everytime i step on it?
thks
Old Feb 18, 2008 | 09:56 AM
mysql101's Avatar
yeah, clutch peddle might be about to snap. If it does, you will be unable to drive the car.
Better take it to the dealer quickly.
Old Feb 18, 2008 | 01:08 PM
laythor's Avatar
I zoom therefore I am.
there's a bunch of threads on this problem, and they're all bad for you.
mysql is right, get to your dealer. There is a TSB about the bracket snapping.
Old Feb 29, 2008 | 05:57 PM
CnnmnSchnpps's Avatar
No means yes
Mine has developed this symptom as well.. For the past couple of months it had just been giving me a little "click" every so often. However, it's gotten worse and now it's creaking pretty loudly.. Feels like stepping on a bag of Tostitos..
The funny thing is, this only happens when the car is warm (or has been driven for a little while). When I start her up in the morning, or when I leave work in the evening, it feels normal. Could this be something besides a failing bracket? I got under there with a flashlight and the welds look sound.. If I press down on the pedal, there is no play at the bolts where the bracket attaches to the firewall, but I get the creaking sound, which may even be coming from behind the firewall, can't be sure..
Things that happened over the weekend that may have contributed to the problem:
- 900 mile road trip
- 100 mile ice race on a very bumpy surface
- getting stuck in the snow banks twice
Could the snow getting under the car have something to do with it? Could something have rattled loose? Most of the race was done in second gear, and the road trip was all highway, so it's not like the clutch got that much use..
I'm gonna be getting under the car tomorrow to try and figure it out, but any tips on what to look for would be helpful..
Thanks,
-D
Old Feb 29, 2008 | 06:22 PM
http://www.finishlineperformance.com...11-06-1724.pdf
Old Apr 22, 2008 | 05:12 PM
Docj78's Avatar
My clutch pedal does the squeak upon depression and realease intermittently as well. I mentioned it to the service writer yesterday after my msp-16 flash, and response was "meh, just spray some silicone under there".
I read some other threads on here where that has stopped the squeak, but has it just "muted" a more significant problem.
BTW, I just printed the TSB^^
Old Nov 13, 2008 | 09:38 AM
SouthFL's Avatar
This thread came up on my noisy clutch pedal search (it's happening to my car now, so I'm reading up on it). I just called the dealer with the cut clutch switch TSB in hand to tell them I was bringing in the car for this known issue. Service person responded with "gee, I've never heard of such a problem and there may be a possibility that we would need to drop the transmission to diagnose the problem"!!! LOL!!!!
Replacement clutch cut switch and Mazsport pedal reinforcement kit have been ordered online. I'll be taking car of this one myself.
Old Apr 15, 2009 | 07:49 PM
sunsilver's Avatar
hey did anyone figure out the actual problem for this, the same thing has been happening to me for a while but i dont think that it can be that cut switch. depressing that thing with my hand even after the car has been driven for a while doesnt make that noise.
Old Apr 30, 2009 | 11:44 AM
tcbon's Avatar
Any one got this issue resolved yet? Please post the update. I recently started having this squeaking clutch issue on my car. My car just passed the warranty period. Any info will help. Thanks.
Old Apr 30, 2009 | 12:03 PM
mysql's Avatar
Doppelgänger
squeaking noise doesn't mean it's breaking.
Watch for the metal to bend, and the clutch no longer be in the original position (it will be shifted to the right or left) - that's the only way to know that it's on the way out.
Old Apr 30, 2009 | 01:14 PM
kersh4w's Avatar
Hit & Run Magnet
go to the dealership, get it replaced. then click the link in my signature to make sure it does not happen again.
Old Apr 30, 2009 | 02:49 PM
mysql's Avatar
Doppelgänger
i have the mazsport clutch bracket. my clutch was not breaking - so this upgrade didn't have any visible advantages. I shift at the same speed. The clutch can still wiggle left and right, and it won't fix squeaking if the spring is the thing causing it.
Old Jul 2, 2009 | 08:16 AM
bsteimel's Avatar
Nice !!!
i believe that i may be experiencing this problem. I have one question. The noise cannot be heard from inside the car only on the outside. Is that true with this problem, cause it appears the clutch cut switch is on the inside of the car? When i press the clutch to the floor is sounds like a dog squeaky toy.
Old Jul 2, 2009 | 08:32 AM
Macius8's Avatar
I have the brackets installed as well, and it still squeaks. The torsion spring just ripped through the bushing and is currently ripping through the sheet metal. Looks like I may need an entire clutch pedal assembly. Make sure the entire assembly looks good and not only the welds.
theblinkof
Oct 4, 2023 05:24 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
