Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
bad luck
Old Feb 15, 2008 | 10:25 AM
gothamite's Avatar
Angry bad luck
it seems i am just having a bad month....
after the problem with the engine dying ( https://www.rx8club.com/gulf-rx-8-forum-32/engine-dying-1-a-137583/ ) but now when i am driving my battery light comes on and then i its followed by my power steering light (and power steering goes out) then ABS, Brake, and tht Stability Control loght come on and it feels like all those systems went out... the car still runs but i dont know whats causing this. i just got a new battery recently (about 3 weeks ago) and i have an amp hooked up to it but i have had the amp for a while and never had a probem. i have check all the obvious places for loose wires cuz thats my idea but they all seem fine. anyone here have any idea what would cause this or will i have to spend the money at a shop or the dealer?
BTW: 2004 w/ 37k miles
thanks in advance!
Old Feb 15, 2008 | 11:23 AM
Uncivilizedracer's Avatar
Turbo SR20deT Son!
Have you tried resetting the ECU yet?
Old Feb 15, 2008 | 11:30 AM
re-rx7's Avatar
EEwww Fresh!
Sounds alt. Related......... voltage test while running and while it does this.
Old Feb 15, 2008 | 02:01 PM
Turbo SR20deT Son!
ANd check the belts if you have not done so already
Old Feb 15, 2008 | 02:56 PM
HERO's Avatar
you're still under warranty so you if you dont find a fix should just take it in to the stealership and have them check it out.
Old Feb 15, 2008 | 03:17 PM
gothamite's Avatar
yeah i did cuz my first thought was that i had busted the alternator belt but its not the case
warranty is for original owner only right? i am the 3rd owner and a salvage title voids that doesnt it?
Old Feb 15, 2008 | 05:11 PM
re-rx7's Avatar
EEwww Fresh!
Test your alternator while it's running........Belt tension.......vaccum lines etc...
Old Feb 15, 2008 | 10:10 PM
w0rm's Avatar
PUSHER ROBOT
How exactly can you blame issues with the car on bad luck when it's been salvaged?
Old Feb 16, 2008 | 11:46 AM
gothamite's Avatar
cuz it happened within a week... and yeah i know i was bound to have problems...
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
duworm
Oct 1, 2015 04:57 PM
Tgiolitto100
Sep 29, 2015 10:52 AM
Learners_Permit
Sep 27, 2015 07:38 PM
