Any Point In me upgrading the Bose to this?
Old Feb 13, 2008 | 12:22 AM
TurboEight's Avatar
Booost.
I have a set of Rockford Fosgate Sitting here.
Model: FRC-4269
http://www.epinions.com/pr-Car_Speak...ay_~full_specs
These are 6x9s, I know these should fit in the stock rear speaker location.
are these even worth my time taking the rear panels out and installing these?
will they make a difference in the sound?
or will it be even worse then the BOSE?
Let me know what you guys think!
Old Feb 13, 2008 | 10:08 AM
canaryrx8's Avatar
well the bose are paper cones, so just about anything would be an improvement, but you might want to search around a bit as I think the only speakers safe to replace in the Bose are the tweeters, and the rest are all rated funky ohm wise. (like the door speakers are 6 ohm, the rears are like 2 or something weird, it's been a long time since anyone has discussed it but I could have sworn I read something to that effect a long time ago. (or maybe it's just my alzheimers )
edit: one more thought, if these are in the rear do you really hear them? seems to me like a waste of time unless you cart around people back there alot, when my system is done I won't even have rear speakers anymore
Old Feb 13, 2008 | 10:37 AM
Socket7's Avatar
ಠ_ಠ
The stock rear bose speakers are 2 ohms. Those ones are 4 ohms, so they are going to be a bit quieter, and you may need to play with the fade. I replaced my rear deck speakers with a set of infinity kappa 2 ways and was very pleased with the result, the sound has a lot more definition now. I'm still using the stock tweeters, but they are going to go away when i finish my install.
If you check the audio info sticky you will find that all the bose tweeters are 4 ohms, the rear deck are 2ohms, the front center is 4 ohms, and the 9 inch door woofers are a 0.5 ohm impedance.
Old Feb 13, 2008 | 10:44 AM
XRX8X's Avatar
more then a Mazda
i have a tweeter in each door a mid range in the center dash with my bose system.are you saying the rear deck has seperate tweeter's or did i read this wrong?
Old Feb 13, 2008 | 10:57 AM
Socket7's Avatar
ಠ_ಠ
The rear speakers in the bose system consist of a 6x9 1 way woofer, and a 2 inch tweeter, both powered seperately by the bose amp. You can replace the tweeters or the woofer without effecting the other.
I urge you to check the audio install reference sticky.
Old Feb 13, 2008 | 06:24 PM
TurboEight's Avatar
Booost.
Alright..
It really seems to be a waste of my time trying to install these.
I 'll just stick with the BOSE.....
No Biggie, Not a audiophile anyways.
Thanks guyz
Old Feb 14, 2008 | 07:28 PM
canaryrx8's Avatar
that's right, forgot about the sticky, ugh
Jst4fun
Mar 5, 2021 07:16 PM
crimson809
Aug 14, 2016 10:03 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
