Traction control/DSC on FI cars
Old Feb 10, 2008 | 02:48 PM
olddragger's Avatar
I didnt know what thread to post this on ---so I'll just go here.
When running an FI car and having a functional TCS and DSC --when those systems activate---do they retard timing AND cut fuel(just speaking about the engine side here)? Should there be a concern activating these systems when you are driving hard and at the upper rpm limits? i dont think i want my fuel cut while i am boosting up high heh
i am thinking it may be better to deactivate these system for a track day event etc?
oldscdragger
Old Feb 10, 2008 | 02:50 PM
mysql101's Avatar
only thing i've noticed is it preventing wheel spin, and sometimes it thinks something crazy happened and disables itself. the traction light goes on and stays on, and from that point the car electronics does nothing.
so no ill effects from what i've seen.
Old Feb 10, 2008 | 02:56 PM
olddragger's Avatar
doesnt cut fuel?
OD
Old Feb 10, 2008 | 03:00 PM
I'm sure they can flash those problems away
I think it closes the throttle body?? Might be wrong tho...
Old Feb 10, 2008 | 03:06 PM
olddragger's Avatar
I would hope so--but am not sure.
OD
Old Feb 10, 2008 | 03:18 PM
staticlag's Avatar
The Professor
Hmm, thats a really good question...
I wonder if the DSC engine cut(fuel, timing) even works with the interceptor x installed. This would probably explain mysql's no problems at this point.
Its probably a different story with people running engine flashes like olddragger
Old Feb 10, 2008 | 03:21 PM
yep,
that is one of the advantages of a drive by wire throttle.. dont recall where i read it.
that is what happening to chrisrx8pr when he has been trying to test the new turbo on the dyno..
Old Feb 10, 2008 | 05:16 PM
sixgen3sgte's Avatar
2JZ Powered
I think the traction control on the rx8 primarly uses the rear brakes to stop wheel spin
i found this out when a shop was trying to dyno my car when it was stock and didn't turn off DSC, i noticed the rear brakes glowing orange so thats when i asked if they turned off the DSC.
Old Feb 10, 2008 | 05:20 PM
Sure they didn't leave your emergency brake on That would be much more likely
Old Feb 10, 2008 | 05:34 PM
2JZ Powered
no they didn't i was in the passenger seat
2JZ Powered
and after i hit the button and turned it off, it workd fine
Old Feb 10, 2008 | 05:42 PM
olddragger's Avatar
Somehow i am thinking that it is not actually closing the TB, rather injector cuts. Gut feeling. For us pettit /flash folks this could be very important
oscd
Old Feb 10, 2008 | 05:59 PM
oscd
od,
i recall chris saying he was watching the throttle closing with a scan tool during the problem dyno runs...
and yes i do understand your concern.. it is a very good point.. i am sure mm will chime in soon..
Old Feb 10, 2008 | 06:10 PM
Brettus's Avatar
Boosted Kiwi
oscd
I did some high speed runs (for MM) to see what was happening with my speed limiter when it cuts in . We came to the conclusion that the only thing it did was close the throttle - all the other parameters changed to suit that condition but the throttle closing was the only thing directly triggered by the speed limiter .
Same should apply for TCS & DSC with the addition of braking .
I have the logs if anyone is interested .....
Old Feb 10, 2008 | 07:16 PM
I doubt that it would cut fuel only...that's asking for it...and it's also way too abrupt to be safe in a TC situation.
TB makes the most sense. I'm going to pull the book out and have a read see what it says
Old Feb 10, 2008 | 07:24 PM
Brettus's Avatar
Boosted Kiwi
hey Danobre - just noticed I'm closing in on your post count - better get busy -heh
Old Feb 11, 2008 | 10:15 AM
olddragger's Avatar
Sounds like tb cut is going on---much relief here! I hope no one else finds anything diff. Still if i plan on a good hard run --from now on i think i will shut that system down.
OD
Old Feb 12, 2008 | 09:55 AM
Red Devil's Avatar
OD
OD, this isn't particularly at you just a general comment...but I always wonder why no one just calls the manufacturer and asks these questions? Pettit designed the kit, they collaborated on the flash, etc...they should know the answer and can allay your worries.
All anyone on this forum can give regarding this specific subject is speculation. Pettit, can actually give you the facts.
Old Feb 12, 2008 | 10:12 AM
olddragger's Avatar
Good idea--thanks Red Devil. Sometimes the obvious is not easily seen. I think I will give Cam a call.
OD
Old Feb 12, 2008 | 05:01 PM
Moostafa29's Avatar
Storm Trooper
x2.
I'm not sure if the TC/DSC works correctly with the Interceptor. I seem to remember spinning a lot, especially when it was wet, and it just kept on going.
Skyl3r
Dec 2, 2019 04:51 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
AussieGray
Jul 16, 2015 03:58 AM
