View Full Version : Air fuel ratio
DonaldNeo
02-08-2008, 04:17 PM
Any advice on wat gadget to use to control air fuel ratio?
Will it helps performance and most importantly get better FC?
Speedrx8er
02-08-2008, 04:55 PM
It will help you tune the car with the proper AFR and you will get more hp out of it.
Yes it is better to know your AFR with FC because it will give you an idea of how rich or lean your car is.. To lean and you could blow your engine.
Brettus
02-08-2008, 05:03 PM
Check it out - a forum dedicated to the subject .
http://www.rx8club.com/forumdisplay.php?f=63
You can't improve much on FC because Mazda already did a good job with that .
DonaldNeo
02-08-2008, 05:15 PM
My friend has an SAFC to tune his car's AFR
so does that work with our 8
or is there any other better gadget to use to control the AFR?
Is ScangaugeII able to monitor AFR?
If Scangauge is ablt to monitor AFR, can I use it to control or tune the AFR to our 8?
Brettus
02-08-2008, 05:23 PM
Racing beat do a flash that leans things out a bit but you can't adjust it yourself with out an EMS - the forum I directed you to . Have a read
Yes scanguage can monitor AFR - but not adjust it .
sammytcl
02-09-2008, 08:16 AM
SAFC does not work on rx8. If you want real time reliable and convenient monitoring of your afr, get a wide band o2 sensor & gauge, such as the innovate xd-16 stand alone kit. If you want to control or tune the afr, get an interceptor-x, or motec, or any stand alone ecu that's compatible with rx8. However, make sure you know what you are doing if you are tuning it yourself.
Zero_Rotary
02-09-2008, 10:22 AM
Howcome my scangauge doesnt show anything on AFR..u sure?
Brettus
02-09-2008, 01:24 PM
actually no - I assumed it would be the same as Scanalyser and have this feature ........
lennon
02-10-2008, 02:31 AM
ECU remap will be the best..... SAFC cannot work on RX8.....
DonaldNeo
02-10-2008, 01:06 PM
I did ECU remapped by KnightSport did they lean the AFR a bit like Racing Beat does?
I heard of another gadget Blitz's I-fit or I-Vit that just need to plug it in like scangauge II that controls AFR. Does that work?
Anyway thx bros for all the advice.
Brettus
02-10-2008, 01:13 PM
yes that would be what they did
I doubt it - what does the advertising say ?
mkl22
02-10-2008, 07:54 PM
blitz i color flash does not control A/F ratios. its also does not display it. so far i know it only works for toyota MarkX and IS250.
lennon
02-11-2008, 01:46 AM
You already did the remap, why still looking for other solution??
DonaldNeo
02-12-2008, 12:48 PM
Looking for more control tats all :)
Anyway thanks for all your advice.
coupe07
02-13-2008, 01:21 AM
control over AF ratio u mean???
for more HP??
