Amp / sub install question
Old Jan 31, 2008 | 09:30 PM
Optical TDI's Avatar
First off, I have the base system, not the Bose.
I want to install a small sub enclosure and an amp just for that sub. Can I run the power line to the battery and get the signal from the rear speakers? I want to avoid pulling the head unit. If I can accomplish, how do I, what do I need, etc.
I looked at the sticky's with no luck. Thanks.
Old Jan 31, 2008 | 09:33 PM
Tigerfootball's Avatar
Clemson, NOT Auburn
a lot of people have used a Line Out Converter to tap into the rear speakers for their signal when adding an amp. So you should be fine. There should be mention of LOC's in one of the stickies.
Old Jan 31, 2008 | 09:56 PM
Juice's Avatar
I made some poos
This will help with wiring an LOC:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-wiring-4-channel-loc-132087/
No need to tap the head unit wires though, as all you need is 2 channels for the sub. Just tap the left and right rear speakers, wire them into a 2 channel LOC and then use the signal outputs on the LOC to go to your amplifier. Power for the amp is gonna come from the battery, ground can be anywhere you want as long as its on the chassis and bare metal. Remote turn on should come from the rear cig lighter outlet.
Old Jan 31, 2008 | 10:00 PM
Juice's Avatar
I made some poos
Oh, the colors in the DIY are the same at the rear speakers as they are coming from the HU. So all you need to do is splice the right color wires together, which are all stated in the DIY. I highly suggest a Navone Engineering line output converter. They are cheap as far as price but work exceptionally well. Unlike some others I have used which crapped out on me, the Navone has held up awesome.
Old Feb 2, 2008 | 12:03 AM
nuke0907's Avatar
Never Blend In
check out my thread too. i have the base system as well. no need to pull the head unit. good luck with the install too.
Old Feb 2, 2008 | 12:08 AM
LOC is your friend
Old Feb 2, 2008 | 12:18 AM
DIY is your friend.
Old Feb 2, 2008 | 01:04 AM
WikkedOne's Avatar
Deals on wheels
search is like your friends hot sister... you should use her often.
Old Feb 2, 2008 | 01:25 AM
nuke0907's Avatar
Never Blend In
oh my
rotarywanker
Dec 8, 2022 05:56 PM
ei8ht
Aug 21, 2017 09:08 AM
talonhart2
Aug 26, 2015 04:14 PM
MolecularConcept
Aug 5, 2015 04:43 PM
Kangarhew
Jul 18, 2015 08:27 PM
