Putting the AT in neutral while at longer stop lights
Old Jan 31, 2008 | 01:08 PM
TurboEight's Avatar
Booost.
Does this do the tranny any good Or BAD?
It seems to be logically it's good, because the tranny sitting at N rather then D and holding down the brakes
Then again it seems to hurt the tranny because of the more often transition from N to D and D to N.
Which one would end up being better?
Old Jan 31, 2008 | 03:45 PM
it doesnt really matter, AT was designed with stop in mind.
I think it actually burn more gas in N than in D with Brakes on.
Just leave it in D.
Old Jan 31, 2008 | 03:52 PM
RotaryP7's Avatar
Seriously.. FML..
Actually, putting the car in N while stopping at red lights saves gas. If you know the light just turned red, it wouldn't hurt putting it in neutral. And nothing will happen to the tranny either..
Old Jan 31, 2008 | 03:59 PM
Nothing will happen of course. but I think for a Rotary it uses more gas to idle than to run.
Old Jan 31, 2008 | 04:03 PM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
unfortunately your correct - nature of the beast.
Old Jan 31, 2008 | 04:06 PM
if you just drive around town for 15 minutes, your gas needle probably will not move much
but if you sit and idle for 15 minutes ... you will cry.
Old Jan 31, 2008 | 04:07 PM
Brettus's Avatar
Boosted Kiwi
No
In D you are putting a small load on the motor which will not only use more gas but put more heat into the engine/transmission - this could cause overheating in extreme conditions (ie hot day with less than perfect radiator etc )
Old Jan 31, 2008 | 04:08 PM
Brettus's Avatar
Boosted Kiwi
no no no
think about it nycgps - at idle afr sits at around 14:1 . At cruise AFR is around 14:1 also . The difference is 800rpm vs 3000rpm - you HAVE to be using more gas when the motor is at a higher speed .
Old Jan 31, 2008 | 06:31 PM
r-enzyme's Avatar
For the Masses
Wink
haha......Couldn't help but laugh on that one. I think I learned the hard way.
Old Jan 31, 2008 | 07:16 PM
Originally Posted by Brettus
no no no
no need to no no no
try it, you'll know what i mean. keep it slow and hmm less than 3 K rpm tho. it will use more or less the same amount of gas (assume that your engine already warm up and ready to go)
Old Feb 1, 2008 | 12:05 AM
bxb40's Avatar
Rotary Newbie
Does the RPM change in N versus D at stop/idle? If yes, then the one with higher RPM might burn more gas. But the one with higher RPM will keep engine cooler too (because the water pump will run faster) and will reduce idle shaking as well. So do the test and draw your own conclusions...
Old Feb 1, 2008 | 12:08 AM
TurboEight's Avatar
Booost.
Lol..I have no idea, guess i'l leave this at D, it's for my mazda3 anyways=P
Old Feb 1, 2008 | 02:35 AM
Galen Darkmoon's Avatar
I don't remember
Slipping it in neutral while coasting isn't good for the automatic transmission as it reduces the amount of fluid/oil pressure available for lubrication/cooling of the clutch packs and bands. That's probably splitting hairs, though, and any gains aren't probably worth the hassle.
Absolutely correct, ever since somewhere back in the sixties when they removed the rear pump from the auto tranny, of course this also negated push starting a car with an auto transmission. AHHH for the good old days as kids driving junkers, we could push start anything. lol
Old Feb 1, 2008 | 03:49 AM
Brettus's Avatar
Boosted Kiwi
Slipping it in neutral while coasting .
who said anything about coasting ?
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Kanthinar
Dec 21, 2015 01:24 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
GrAfiX
Aug 24, 2015 08:08 AM
Belalnabi
Jul 17, 2015 07:48 PM
