kw's in new RX8
Old Jan 30, 2008 | 12:41 AM
matt13b's Avatar
kw's in new RX8
I know that the australian RX8's had to be de-tuned to 170kw from 06 onwards I think it was,due to the emissions laws here.So the RX8's from the last few years have 170kw while the first ones had 177kw.So if the new RX8 is identical to the current RX8 mechanically(with the exception of the diff ratio),then won't it have 170kw like the current RX8's do here??
Old Jan 30, 2008 | 12:52 AM
All they did was change the way they measured the rated HP
Old Jan 30, 2008 | 12:53 AM
Cromax's Avatar
Buzz Buzz Buzz
That is what the articles say from what I've read.
Old Jan 30, 2008 | 12:54 AM
Cromax's Avatar
Buzz Buzz Buzz
No ... your'e talking about something different.
Old Jan 30, 2008 | 01:30 AM
DrGonzo's Avatar
Assuming the outputs are the same, with the shorter ratios will that mean that the torque will increase?
Also, I read somewhere that the auto picks up a bit of power thanks to a new transmission.
Old Jan 30, 2008 | 02:45 AM
Cromax's Avatar
Buzz Buzz Buzz
Yeah, but it probably picks up a lot better because I recall reading that it was running the same setup as the manual now (bar the fact the transmission is differnent).
Old Jan 30, 2008 | 03:19 AM
auzoom's Avatar
Hmmmmmm.........
The point of the final drive ratio change was to increase acceleration. This will show an improvement in torque at the wheels but the engine itself hasnt changed.
dannobre, for real? I was of the belief it was an ECU/tunning affect.
Old Jan 30, 2008 | 05:11 PM
matt13b's Avatar
I wonder how hard or expensive it would be to change the diff ratios on our rx8
's to the new RX8 ratio??
Old Jan 30, 2008 | 07:51 PM
takahashi's Avatar
I rather go for aftermarket ones. The final drive is in the diff. I will at some stage change final drive an LSD together
Old Jan 30, 2008 | 10:19 PM
matt13b's Avatar
I just had a look at the Knightsports catalogue and they sell a kit to change the ratio to 4.777?? Maybe I will look into that..
Old Jan 31, 2008 | 02:57 AM
auzoom's Avatar
Hmmmmmm.........
There are a few around that offer them. If you are interested in the KS one, speak to Jason at REVS...fdracer here.
Old Jan 31, 2008 | 03:29 AM
matt13b's Avatar
I will.Thanks for that.I just got the brochure from Jason today,that's where I saw the kit.Lots of good stuff in there!
Old Jan 31, 2008 | 05:48 PM
Cromax's Avatar
Buzz Buzz Buzz
You're thinking of going with a 9" diff?
Old Jan 31, 2008 | 08:00 PM
takahashi's Avatar
Any 2 way diff is good enough for me
Old Feb 1, 2008 | 12:18 AM
auzoom's Avatar
Hmmmmmm.........
Nate, he is thinking of a 4.777 ratio diff
Old Feb 1, 2008 | 12:32 AM
Cromax's Avatar
Buzz Buzz Buzz
Oh, ok ... why?!
Old Feb 1, 2008 | 06:00 AM
auzoom's Avatar
Hmmmmmm.........
same reason Mazda is doing it for the SII.
Old Feb 1, 2008 | 06:06 AM
takahashi's Avatar
I found a 5.222 something final drive too... but I prob go for 4.777 ... well time to save up.
Old Feb 1, 2008 | 06:10 AM
auzoom's Avatar
Hmmmmmm.........
with 5.222 you wouldnt need 1st gear would you!
Old Feb 1, 2008 | 04:39 PM
Lennart's Avatar
Honda S 2000 have 4,777. You can use this in Rx-8.
Where did you find 5,222. I`e a racecar and should like to have that one. The car is not streetlegal and I`e DNA- kompressorkit inthe car.
Old Feb 1, 2008 | 04:45 PM
Lennart's Avatar
A photo of my "Racecar a`la Rx-8".
Old Feb 2, 2008 | 03:58 AM
takahashi's Avatar
I remember you well... LP
5.125. It is limited offer. So I don't think a set will get out of Japan.
http://revo-tune.jp/catalogue/detail.php?id=171
I will still want Nakamura san's product...
Old Feb 2, 2008 | 06:15 AM
Lennart's Avatar
Thank`s for your answere. I`ll try to get one thrue my contact in Japan. If it works out I`ll post a reply here.
Old Feb 5, 2008 | 02:18 PM
Lennart's Avatar
Thrue my friends in Japan I`ll have one in Sweden end of Februari.
Old Feb 21, 2008 | 09:08 PM
Lennart's Avatar
My Final Gear has arrived. Will install it next week.
Attached Thumbnails kw's in new RX8-p080220-2.jpg   kw's in new RX8-p080220-3.jpg
