Rim fitment question ???
Old Jan 29, 2008 | 05:55 PM
OBTIQ's Avatar
>> Motion
Well im this close to cutting a deal on some rims but I need to know if they will fit first.... The front are 18x9 41offset and the rears are 18x10 45 offset
If they fit they'll hopefully be on my car next week, and i'll post pics up asap.
Old Jan 29, 2008 | 06:20 PM
OBTIQ's Avatar
>> Motion
also what size tires should I be aiming for
Old Jan 29, 2008 | 06:24 PM
They should fit well
Staggered sizes 265/275-35-18 Rear
245-40-18 or up to 265/35-18 front....(265 bit wide for 9" rim though)
or you could run 265 on all 4 corners...
Old Jan 29, 2008 | 06:32 PM
OBTIQ's Avatar
>> Motion
I also have tein s-tech springs, So Im going to have to roll the fenders rights... also will I need to adjust my camber in any way
Old Jan 29, 2008 | 07:37 PM
OBTIQ's Avatar
>> Motion
anyone know if im going to need to roll my fenders or adjust my camber ????
Old Jan 29, 2008 | 07:53 PM
sammytcl's Avatar
depending on what size of tires you are running.
any size under 265/35/18 in front and 275/35/18 in rear on your rim sizes should not require rolling fenders, but maybe need to camber in a little bit more.
Old Jan 29, 2008 | 08:34 PM
OBTIQ's Avatar
>> Motion
well I just bought the rims, so Im going to have to do 265 for the front 275 for the rears ???
Old Jan 30, 2008 | 02:11 AM
sammytcl's Avatar
I have a customer that's running 265/35/18 with 18x9 35mm offset in the front with -1.5 camber and lowered, and no need to roll fender. On the rear, he is running same size but have to roll the fender.
People have been running 18x9.5 45mm in rear with 275/35/18 without any issue, so you should be good, unless you are going to run oversized racing tires such as the Toyo R-888.
Old Jan 31, 2008 | 12:59 AM
Rx8-13b's Avatar
i hve 18x9 in the front and 18x10 in the bak offset 41 in front and offset 45 in bak also with tein s tech springs, no camber adjustment at all just fender roll, tires are 235/40/18 and 265/35/18, no rub at all, perfect
Old Jan 31, 2008 | 01:29 AM
aliveoutofhabit's Avatar
I would like to see this happen asap.
Old Jan 31, 2008 | 10:34 AM
kennychopra17's Avatar
Joe, whats up. I just bought some SSR's as well. there 19 x 9.5 all around with +40 offset on all 4. Looks like i might do 255/35/19 all around or a stagger 245/40/19 in the front and 275/35/19 rear; and I hear that I will not have to roll fenders. I am also Not dropped yet, so maybe its different. Let me know how it turns out - ken
LB2739
Jul 9, 2019 02:25 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
yapakanichi
Sep 17, 2015 04:23 AM
yankeepicker
Sep 11, 2015 05:42 PM
Rupanrx
Sep 4, 2015 06:44 AM
