225 or 245, best for stock 8" wheel?
Old Jan 24, 2008 | 08:10 PM
Bester's Avatar
07 6M Black
Quick question if I may.
Dont compete with this car, so the answer is not really critical. Plan to autocross for fun, maybe HPDE if my schedule will allow.
From what I know you want the tire width to be even with the wheel width. Most cars that have 245 tires mount them on 8.5' or wider wheels. Is the "extra" grip afforded the 245 versus the stock 225 offset somewhat by the narrower tire to wheel ratio? Or would I or anyone even notice the difference. I like the tight feel the car has an if a too wide a tire (per wheel width) is used it will cause the car to feel mushy with steering inputs.
I know, a 275/35R18 on a 10" wheel would be great, but just curious what would work best with the stock wheel.
Old Jan 24, 2008 | 08:40 PM
chancejat's Avatar
Drive it like u stole it!
+1.....curious how much wider i can go on stock 18's
Old Jan 24, 2008 | 08:46 PM
staticlag's Avatar
The Professor
245 is the widest you can go on stock wheels.
But it really depends on what tires you are planning on running and at what pressures. As far as mushyness.
generally I will recommend a 235 on stock wheels, The 245s felt too loose for my tastes for the setup that I run.
Old Jan 24, 2008 | 08:49 PM
Spin9k's Avatar
Momentum Keeps Me Going
From what you say you know the answer. Still, 'better' and 'best' is a fuzzy science here with a lot depending on the tire and a lot of combos work with + and - attributes for each.
Old Jan 24, 2008 | 09:22 PM
chancejat's Avatar
so 235/40/18???
Old Jan 24, 2008 | 10:33 PM
spend some time on tirerack.com it is a bit tire dependent... you can look at a tire size and it will give you a recommended wheel width...
i am running 245 / 40/ 18 on lightweight 7.5 inch width wheel.. works just fine..
Old Jan 24, 2008 | 10:42 PM
all the national level autocrossers run 245/35 or wider if that helps
Old Jan 24, 2008 | 10:52 PM
I loved the 245 set up.
I went back to 225 because the diameter is smaller. I don't like it. It's more stable with the 245's.
I went to 225's to see if I can drive on the street since they are .8" lower.
If it works they I go to 17" wheels. So far I can get around but never over any speed bumps.
Old Jan 24, 2008 | 11:46 PM
am a bit confused..
as talked about..
225 / 45 18 is 25.9 in dia.
245 / 40 18 is 25.8 in dia.
these sizes are what people do on a stock wheel.. as the dia controls the speedo error..
what aspect ration are you running??
Old Jan 25, 2008 | 12:13 AM
My last 2 sets of tires have been 245/40. Love 'em
Old Jan 26, 2008 | 07:53 PM
musclecarconvrt's Avatar
245/40 18s for the last two sets of tires for me. No rubs, no problems. Just ordered a third set of the same size.
Old Jan 26, 2008 | 08:05 PM
first-rotary04's Avatar
wankel? what's that?
what about handling ?? better ot worse ??
what about pricing?? cheaper or not??
recommendations on any specific brans ??
thanks before hand
Old Jan 26, 2008 | 08:49 PM
Kuhmo Ecsta MX 245/40 18s are what I've run the last two sets. Very good grip in the summer. Much less expensive than most. Better than the stock Potenzas. Think I paid about $150 each last time. Decent mileage for a summer tire at around 30k. They take a long time to warm up when it's cold out and forget about snow.
My wife's MS6 has Pirelli PZero Nero MS that give a nice smooth ride and decent grip for a MS. This is a great all season tire at about $168 per tire.
Old Jan 26, 2008 | 09:36 PM
The 225/45-18 Bridgestone Pole Position S03 is on a closeout sale at Tirerack for $125 each, that;s quite a decent street tire wet or dry for the price
Old Jan 26, 2008 | 11:35 PM
dothackRAVE's Avatar
<3 Rotary
Thanks for the headsup. Been looking for tires with a similar treadwear as my old Ventus RS-2s (because no one ******* sells them in my sizes... ). $125 for tires that usually cost $200+ is REALLY cheap.
Old Jan 28, 2008 | 12:11 AM
parkpy's Avatar
Umm...RS2 Z212s are available in 235/40R-18 at edgeracing.
MANY tires are available in a 235/40R-18. You can also fit 245 width tires as well.
Old Jan 28, 2008 | 08:27 AM
spooledUP7's Avatar
If you want an affordable tire with great track grip for next to nothing then try the Fusizon ZRi. Tire rack sells them.
The tires look pretty nice too.
Old Jan 28, 2008 | 09:55 PM
Depends upon how you drive.
For handling:
225's for nimble
245's for high speed manuvers
Old Jan 28, 2008 | 10:37 PM
Just go with 245's.
Old Jan 29, 2008 | 06:57 AM
chancejat's Avatar
will do....thanks
Old Jan 29, 2008 | 10:20 AM
Scrapin 240's Avatar
Originally Posted by chancejat
will do....thanks
btw 245/40 is cheaper than 225/45 which is a great benefit
Old Jan 29, 2008 | 07:08 PM
CodingParadox's Avatar
I really like the 245/40/18 GS-D3s I put on my stock wheels. They look good and handle fantastically.
Old Jan 29, 2008 | 11:30 PM
devildog1679's Avatar
I run 245/40 MX's and hey feel great at HPDE's.
Old Feb 4, 2008 | 06:30 PM
EricMeyer's Avatar
For racing, you want a 225 on a 8.5 - 9.0 wheel. This is to minimize the side wall flex. This would be for a Hoosier or Hankook or Toyo race compound tires.
9" works with 245 nicely too.
Get the 245's as your grip increased quite a bit. Mount them on 9's if you can. 8.5 would work but 9's is best.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Paul_Y
Sep 21, 2015 02:23 PM
DVerdeyen
Sep 13, 2015 11:19 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
