The rx-8 at idle??
Old Jan 21, 2008 | 09:26 PM
OSducky's Avatar
The rx-8 at idle??
Ok this is kind of weird and i dont know if its normal for an rx8 or if my engine is messed up and I just dont know it, but If I throw the car into neutral at like a light or something, the SOUND of the car is almost like it "revs up" but not like a FULL throttle rev, just like a little bit, is this normal, or something wrong with the engine?
Its really hard for me to explain, Like it revs, but not loud? haha I need to go find some sound clips
Old Jan 21, 2008 | 09:29 PM
chancejat's Avatar
Drive it like u stole it!
if its an automatic its normal....if its like a 100-200 rpms.....when its in drive theres a load on the engine thats why you have to hold the brakes at stop lights
Old Jan 21, 2008 | 10:32 PM
maybe you could explain some stuff like where you are from..
auto or manual. how many miles.. last flash... anything?
Old Jan 22, 2008 | 04:55 AM
fugg's Avatar
is this the same sound as when your idling @ start-up? sort of sounds like an alternator going out in a piston engine?
if so, thats normal. (i hope)
Old Jan 22, 2008 | 05:08 AM
picnik's Avatar
Think I know what your talking about, when I start my car in my driveway. It revs up to about 2000rpms and slowly goes down. I noticed it only happens when I start the car on a slope.
Old Jan 22, 2008 | 12:39 PM
nonconfrontational's Avatar
alter ego:confrontational
Does it seem to rev once, or does it tend to go up and down?
When my engine went out it jumped between 500 and 1200 revs all by itself in neutral at stoplights, like it wanted to stall.
More info needed on your situation, as stated above.
Old Jan 22, 2008 | 12:47 PM
JRichter's Avatar
Void Where Prohibited
Mine rpm fluctuates when the fan is on and the car is idling in neutral. If I turn the fan/ac/heat all the way off it usually returns to a smooth idle. It's done this as long as I remember so I call it normal.
Old Jan 22, 2008 | 12:50 PM
JRichter's Avatar
This sounds like the car trying to warm up a little and is normal. If it doesn't do it when the car is cold and your not on a slope then you got me.
Old Jan 22, 2008 | 02:10 PM
zerobio's Avatar
Atomic 8
This has happened with every car I've owned. Idle starts out high when cold, drops to around 800 or so and stays there but once in a while goes up a bit and down a bit. i think it's normal.
Old Jan 22, 2008 | 02:32 PM
DOMINION's Avatar
I don't buy Kool-Aid
Thats normal. Also what he is experiecning in normal AT or MT the 8 will do this.
Old Jan 22, 2008 | 04:07 PM
chancejat's Avatar
^^^^the origanal thread poster is not talking about that...........^^^^
Old Jan 22, 2008 | 04:13 PM
huzer21's Avatar
Mine yo-yos, only when it's cold. Upon startup, I'll will cycle between about 1500 and 3200. Constantly, for about the first 20 seconds the car is running, and only when the clutch is engaged. Once it's warmed up, it's fine. I don't notice any performance issues, so I just assumed this was normal.
Old Jan 23, 2008 | 03:23 PM
04RX8man's Avatar
Rotary Powered Countryboy
Mine has been in the garage so long for winter I don't even remember. (I miss my baby) But as far as I can recall my MT does a little but barely noticeable unless no music on and watch the rpms's
ironj221
36
Jan 20, 2026 08:28 PM
gwailo
May 14, 2024 06:57 AM
Nisaja
51
Sep 1, 2015 04:29 AM
dbarber
Jul 25, 2015 01:34 PM
vssystemluba
Jul 19, 2015 04:16 PM
