View Full Version : Cant get in the car!
AdoRe 01-12-2008, 11:30 AM My car (2004 gt) is stored since 1st nov. but now the battery seems drained, the keyless wont work. The key in the lock wont unlock the door..i cant open the hood cause i cant get in ect...i only can go in the trunk...any help is appreciated
staticlag 01-12-2008, 11:42 AM Why won't the key in the lock unlock the door?
staticlag 01-12-2008, 11:45 AM But realisitically, the easiest way to fix this problem is to hook up a car battery to the 12v+ and 12v- wires going to the rear speaker amplifier.
Should give just enough juice to let the keyless entry unlock the doors.
At your own risk of course :)
Try turning the key in the door the other way...
staticlag 01-12-2008, 11:49 AM next easiest (free) way is to jack the car up and hook another car battery up to the starter 12v+ line and any ground point.
Mazurfer 01-12-2008, 11:49 AM And if the lock is kinda frozen(won't turn), you could spray just a little bit of wd40 in there. I'm NOT sayiing to do this, but it's an option.
In the past on other cars, I have lightly coated the key with 3-in-1 oil and been able to free it up that way.
Mazurfer 01-12-2008, 11:51 AM That actually sounds a little better than the speaker amp, but is a little more physically dangerous not knowing the OPs ability level.
I can see it now................we will be making a DIY that runs spare cables down to some aux position on the underside of the car, trunk, or maybe hidden behind the plate for this purpose! Wait....let's put it right in the front nose opening.............maybe between the front accent piece!
AdoRe 01-12-2008, 12:04 PM i dont know, the key turn but seems free both sides...and it is not frozen .. a dont know now what to do:banghead:
Mazurfer 01-12-2008, 12:12 PM Do you think your trunk pass thru is in place and locked?
If you can get a small person through there you'd be set.
For all I know, you might be able to turn the trunk lockout flange from inside the trunk?????????
If not..do as Staticlag suggests with another battery to the starter from underneath if you feel comfortable. If not you might have to call a locksmith.
I still thinking, will let you know if I come up with anything else.
Jedi54 01-12-2008, 12:31 PM whoa, this is a strange problem to have.
do you have another key you can try? New cars usually come with 2 copies and a valet version.
You could always call Roadside Assistance and have them come open it for you.
dannobre 01-12-2008, 12:50 PM hit the door really hard above the passenger handle
That won't work without power to the key switch ;)...and it's the drivers side :)
AdoRe 01-12-2008, 01:19 PM a locksmitch would dammage my window/door seals or paint...
and it dont work with the other key to its like the lock is free...
and my rear hole is lock i tried that..
DarkBrew 01-12-2008, 01:22 PM Sorry for your trouble... but... it could get worse
You didn't prep your car for storage?
Did you at least add fuel stabilizer?
How about the tires? are you preventing flat spots somehow?
I really hope it works out for you.
Mendossa 01-12-2008, 01:38 PM I don't get it... keyless entry system "overrules" the mechanical lock?
I have a 2004 GT *without* keyless entry and I can lock/unlock my doors just fine using the key while the car is sitting in storage without a battery in the car.
Sounds pretty stupidly engineered to me if keyless entry without power means no way of unlocking the car.
Mazurfer 01-12-2008, 04:20 PM I don't get it... keyless entry system "overrules" the mechanical lock?
No that's not it....apparently his lock is messed up(can't use key) and he doesn't have enough juice in the battery to unlock the doors electrically.
ShinkaTeen 01-12-2008, 04:41 PM Try turning the key in the door the other way...
HAHAHAHAHAHHAHAHAHAHAHAHAHHA
ken-x8 01-12-2008, 05:24 PM a locksmitch would dammage my window/door seals or paint...
A good locksmith would not. Yeah, you should worry about a tow operator randomly jamming a slim-jim around, but locksmiths are a lot more skilled than that.
Ken
laythor 01-12-2008, 06:33 PM http://www.petbrick.com/brick.jpg
http://www.speakwell.com/well/2004summer/media/pitcher.jpg
http://www.classact.ca/RubberStamps/Miscellaneous/FP25C_C_LargeHappyFace.jpg
AdoRe 01-12-2008, 06:36 PM i found a way to get in i will jump directly from the starter power source from under the car..thanks anyway!=)
nycgps 01-12-2008, 09:55 PM you found a way good.
What I will do is make a little hook using a hanger, pile the Door slightly so I can slip it in, then unlock the door with the little hook.
not hard to do.
Jedi54 01-13-2008, 12:51 AM I award you the "Post of the Day" award!
Startl_Respons 01-13-2008, 02:03 AM Buy the graphite powder (dry lubricant) that you squeeze into the key hole. Costs $1 to $2.
CnnmnSchnpps 01-13-2008, 02:23 AM http://www.petbrick.com/brick.jpg
- I gotta get my tool.
- That's not a tool... that's a damn brick!
laythor 01-13-2008, 03:38 AM gone is 60 seconds
laythor 01-13-2008, 03:38 AM I award you the "Post of the Day" award!
woot!
Mazurfer 01-13-2008, 09:39 AM I am unfamiliar with this particular species of brick. Is that a "Mercedes brick" or just a "Peace Brick"? or something completely different.
By the way Laythor...............you were a huge help to the OP. :lol2:
CnnmnSchnpps 01-13-2008, 09:51 AM gone is 60 seconds
correct...
"We gonna use a brick, we might as well call the prison and make reservations"
Nixrx8 01-13-2008, 11:06 AM You should get AAA- as said above, a good locksmith will not damage your car.
laythor 01-13-2008, 02:31 PM Mazurfer, I searched around looking for something helpful and when I cam up empty I decided to go the smart ass route.
Mazurfer 01-13-2008, 02:33 PM Mazurfer, I searched around looking for something helpful and when I cam up empty I decided to go the smart ass route.
:) I was just razzin ya!
That was pretty good..ye ole brick trick!
zoom44 01-13-2008, 02:39 PM both doors lock cylinders dont work?
Mazurfer 01-13-2008, 02:44 PM both doors lock cylinders dont work?
You got one on the passenger side? I don't.......'05
Unless I'm completely nuts...........and it's stroming out, so I'm not gonna go look.
staticlag 01-13-2008, 04:05 PM lol, even in the picture of the red rx8 on the top of this site there is no passanger lock :lol:
zoom44 01-13-2008, 04:34 PM sorry momentary lapse of reason
Mazurfer 01-13-2008, 07:30 PM Phew, I feel better. Thought I was having a bout of oldtimers!
Yeah...about the red car at the top, I never noticed that. :)
XRX8X 01-15-2008, 12:58 PM seems like someone was trying to get into your car and popped the clip off your door lock/latch assy.once removed you might need to have the clip replaced by taking off the door panel and inspect for damage.hope this helps
