Sunroof Leaking!!!
Old Jan 9, 2008 | 06:28 AM
VolcomStoneX's Avatar
Hi, Let's Make Out
Sunroof Leaking!!!
So i took my rx8 Saturday for the sunroof recall, because the rattle was annoying, and i barely got a chance to pick it up yesterday, and when i got back to work it was raining, after work was out and all, i walked up to it, and noticed moisture on the inside of all the windows!!! im pissed now, and there was water (not much) but still in the tray on top! im going back to Mazda today. the closest dealer is 30 minutes from my house.has anyone else had the sunroof recall done?
i just needed to vent, thanks
Old Jan 9, 2008 | 06:34 AM
enforcer's Avatar
The search button is your friend. This may help... https://www.rx8club.com/search.php?searchid=3238385
Old Jan 9, 2008 | 06:35 AM
Hi, Let's Make Out
i did search but i didn't see (at least) someone else that got the recall done
Old Jan 9, 2008 | 06:52 AM
enforcer's Avatar
Hmmm...you're right...there isn't much out there. A couple of mentions....
https://www.rx8club.com/showthread.p...t=rain+sunroof
It sounds like you're still in warranty, they have to fix it...end of story...
Old Jan 9, 2008 | 09:17 AM
reaper1's Avatar
I had the recall done early last year . The issue was taken care of . Seems one of the techs didn't install your sunroof right .
Old Jan 9, 2008 | 09:35 AM
DarkBrew's Avatar
Extraordinary Engineering
Typical issues with the Mazda 'techs' work on the sunroof are;
Sunroof panel installed backwards
Sunroof panel not level with roof
Your issue I've not heard before. If you want to save the trip...
Have a look at the seals to see if one edge is compressed more than the other. (if the seal is damaged then go back to the dealer) You can re-align the sunroof panel by loosening the four bolts (two per side) that hold the panel to the rails. Do this with the sunroof in the closed position. The seals will hold the sunroof panel well centered so all you have to do is hold it at the right height and tighten the bolts. It take a bit of fiddling but it works well.
Old Jan 9, 2008 | 09:37 AM
staticlag's Avatar
The Professor
I thought this was the case. My sunroof was fixed by the recall and readjusted and everything. Had them take it in 4 times, they replaced every part of the sunroof and all the drains.
Turns out it was the windshield glass leaking up by the headliner. Long story short, I got a new free windshield from Mazda factory Warranty.
So I would wager that its your windshield that got shifted when they were working on your sunroof, just like mine.
Old Jan 9, 2008 | 09:52 AM
Hi, Let's Make Out
that sucks! as soon as i got it back, one side looked more depressed, than before, i knew something was gonna be wrong, i tested this when i got home, got a little bit of water and poured over the seal, and surely, the water was seeping into the seal, i was furious,
thanks for all the help guys, its good to know some people actually helped instead of bitching at me for asking a question
Old Jan 9, 2008 | 10:08 AM
enforcer's Avatar
This the appreciation you get when you search the forum and post up the threads for some guidance...you can count me out next time you ask something.
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
DG07
Sep 28, 2015 10:58 AM
Tsurugi
Sep 7, 2015 08:27 PM
