View Full Version : Inside wheel spin?
thatkarelguy
01-07-2008, 04:59 PM
Drove down to Phoenix this past weekend for 2 trackdays at PIR.
While down there I noticed that i get a bit of a clunk noise and hear some inside wheel spin when I do any slow speed maneuvering around a parking lot. Seems to happen especially after reversing out of parking spot. Not sure if it's always been doing it but I don't remember it being as pronounced. I have been driving in snow for the past 2 months so I bet the wheel spin wasn't as apparent as it was when i was on some clean roads in PHX.
I have 18k miles on the car. Figured it's about time to replace the differential fluid especially after doing a couple track days. Diff seemed to be working fine at the track, but I'm sure my power of perception isn't perfect. Anyone else have this problem - is it normal for an LSD?
TrochoidMagic
01-07-2008, 08:13 PM
hmmm, binding friction plates? dunno, but that'll be my guess.
Razz1
01-07-2008, 09:46 PM
sand on the road?
mysql101
01-07-2008, 09:49 PM
Does the klunk happen once, or more than once? The ABS self test takes place just after you start moving, so you should have a single klunk normally.
thatkarelguy
01-08-2008, 09:32 AM
Clunk will happen once whenever I make a slow turn. Don't have to shut the car on and off. I think.....
I'm back in Flagstaff now and we got 18" of snow sunday night. Probably won't be able to check for sure for a little while.
elysium19
01-15-2008, 07:05 PM
This sort of thing happened to me, three times in 2 days, right around the time when it had gotten freakishly cold for a little bit here in new york (down to ~8 degrees F for about 2 days). A clunking sound when reversing (and turning) slowely, sounded like it came from the rear wheels. It only happened once each warmup cycle (meaning it happened once as I backed out of the driveway to go to work, and once again as I left work and the car was cold again.)
My memory is fuzzy, but I remember someone making another post about a similar thing, and I remember it being related to cold weather and during slow reversing.
Any other experiences???
chancejat
01-15-2008, 07:07 PM
id say its the dsc.....
elysium19
01-15-2008, 07:10 PM
I replaced my diff fluid with Redline
how could this be related to DSC when going 3mph?
elysium19
01-15-2008, 07:28 PM
Makes sense....although I dont understand how some relatively sticky gear oil could result in a "clunking" noise.....but really, i believe you, mostly cause it hasn't happened since :eyetwitch
TeamRX8
01-15-2008, 07:52 PM
We don't have friction plates in our diff. We have have gears in our Torsens.
It's only real similarity with a Torsen is that it's a torque sensing type of limited slip. It uses a cone ring engagement rather than gears.
http://www.mx5plus.com.au/images/parts/b39.jpg
http://www.mx5plus.com.au/images/parts/c39.jpg
You may have blown the limited slip. I have a low mileage one if you're interested. A drivetrain company will charge you around $300 + parts to install it if you remove/install the differential yourself. The price jumps dramtically if they have to remove/install the differential too.
Or you can just buy my complete differential with Kazz LSD and plug & play, only some limited street use and a few autox events on it
http://www.rx8club.com/showthread.php?t=134056
TeamRX8
01-15-2008, 07:56 PM
Not knocking you. I thought it was similar to a Torsen too (as did most of us here) until actually removing one and putting my hands on it.
