Ok ...how do you find the difference b/t crank hp and whp
Old Jan 6, 2008 | 12:28 PM
R3v9K's Avatar
R3V9K
is there like a math problem or something that will tell you how much crank hp you have. Can you take your whp numbers and convert them? i was just wondering this during work lol.
Old Jan 6, 2008 | 12:34 PM
mysql101's Avatar
depends on the car. For the rx-8, it's 11 - 15% less for whp vs crank.
r0tor's Avatar
either get dyno results from the same engine on an engine dyno and chassis dyno and compare.... or do a whole lot of research, get a Mechanical Engineering degree, and do a whole lot of calculating
...or just make use of a general percentage assumption
Old Jan 6, 2008 | 12:46 PM
Brettus's Avatar
Boosted Kiwi
I'm guessing the losses (as a percentage) reduce significantly as you increase the hp by boosting ?
Old Jan 6, 2008 | 12:47 PM
StealthTL's Avatar
Metatron
You can test it yourself - enter quarter mile times and speeds, weight etc. and it will give you a rough estimate.
http://www.dragtimes.com/horsepower-...calculator.php
S
Old Jan 6, 2008 | 12:53 PM
mysql101's Avatar
The problem is few of us are taking our engines out and doing an engine dyno then doing a regular dyno to compare.
We estimate based on the numbers we do have. I guess it matters if you think Mazda is accurate with the 232 hp claim.
RevMeHarder
Jun 1, 2026 02:30 PM
DVerdeyen
Sep 13, 2015 11:19 AM
titaneum_grey
Sep 6, 2015 10:21 PM
iwannarun
Sep 6, 2015 01:37 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
