Possible to mod the heater to use recirculated air for the defroster?
Old Jan 5, 2008 | 07:58 PM
demon's Avatar
May seem like a bizarre need, but I need to modify my heater such that I can use the windshield defroster while still set on internal air recirculation. Everytime the defroster is chosen it automatically switches to external air and can't be changed back.
Anyone done anything like this or have any ideas?
Thanks in advance!
Old Jan 5, 2008 | 08:11 PM
Revvittupp's Avatar
It won't work as well as you will being throwing more humid air at the windshield.
Old Jan 5, 2008 | 08:53 PM
demon's Avatar
Understood, but I still need to do it
Any tips are appreciated!
Old Jan 6, 2008 | 02:56 AM
WoodsOfGreenRx8's Avatar
Why do you NEED to do it, as you have stated?
Old Jan 9, 2008 | 09:32 AM
staticlag's Avatar
The Professor
Uh, why? You do understand that by setting this up, your vents will actually CAUSE your windows to fog up, right?
Its really not what you think.
Old Jan 9, 2008 | 09:33 AM
staticlag's Avatar
The Professor
Or are you trying to use the COBB tuner?
Old Jan 30, 2008 | 02:46 PM
MyRXdrug's Avatar
I was wondering the same OP's question. I put the defroster on recycle in my old corolla so the car will warm up quicker. They don't fog up if I am not in the car usually.
Old Jan 30, 2008 | 02:54 PM
StealthTL's Avatar
Metatron
We have terrible frost problems here, but the answer is not recirc -
When it's minus 30* here and you put it on re-circ it will fog up/ice up and you're screwed.
Interesting fact - the difference between inside air and outside air is less than 2 degrees at the vent outlets, even with 40 or 50 degrees difference in outside temp..... Put a thermometer in the vent and swing between the two settings if you need proof.
What 'just makes sense' ain't always true.
S
Old Jan 30, 2008 | 03:01 PM
MyRXdrug's Avatar
Won't the engine heat up faster though?
Up here where it is dry, I don't have problems with recirc on the windshield if I am not driving it. I put the vents to recirc when warming up the car. I notice that the engine warms up faster and there is no fogging up.
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Hunter of Gunmen
Sep 21, 2015 06:27 PM
