OEM air filter
Old Jan 1, 2008 | 05:35 PM
ScottyStyles's Avatar
Tailhappy
OEM air filter
I used search, but I either suck at using it, or it's not on here...
How long do the OEM air filters last, on average? I live in Idaho, so there's no environmental thing that will clog up the air filter fast or anything to that affect.
*edit: I should mention, I'm posting this here, because once I need to replace it, I'm going to get a different filter... K&N or Green, still undecided which.
Old Jan 1, 2008 | 07:29 PM
invasion08's Avatar
replace every 30k
Old Jan 1, 2008 | 07:51 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Where the hell is Shini when I need him?
Seems to be MIA at the moment!
Old Jan 1, 2008 | 07:55 PM
Mazda saids about 30K
but for me, I say 15 K the MOST.
Filters cost less than an engine, u know.
Old Jan 2, 2008 | 09:38 PM
foo77's Avatar
4th batch : Apr 03'
^ +1 if you want to change it, get K&N coz it'll last long
Old Jan 3, 2008 | 02:33 AM
Tailhappy
What makes K&N last longer, how much longer, and is there much of a tradeoff with performance there? I got the impression that with care, they both lasted about the same time. Only reason I'm upgrading is because I do autocross, and it's one of the easier, cheaper switches to make and stay in the stock class
Old Jan 3, 2008 | 03:04 AM
TrochoidMagic's Avatar
is adjusting valve lash
filters r not hard 2 change. dealers in cali recommend every year or 15k. and cali is considered extreme environment.
so a lil common sense can keep ur car happy. if living in a cold climate with less floating dust particles, it only makes sense that the filter will stay cleaner longer.
say u live in a rainy place like seattle, ur filter will hardly get dirty. so just a refreshing of the filter is still a benefit when u see 20k or so.
hope this helps...
Old Jan 3, 2008 | 07:21 AM
invasion08's Avatar
k&n lasts longer because you can clean it and re oil it yourself
Old Jan 3, 2008 | 07:51 AM
VolcomStoneX's Avatar
Hi, Let's Make Out
i just ordered one from a local auto parts store, but its taking forever for them to get it, what kind of oil do i use? and where can i find it?
Old Jan 3, 2008 | 08:09 AM
The K&N drop in filter itself should cost around 40-50 something bux.
For the oil, you can get their K&N filter recharge kit. it comes with the spray to clean the filter. and the oil so you can re-oil it afterwards.
For more information, go http://www.knfilters.com/
Old Jan 3, 2008 | 10:14 AM
Hi, Let's Make Out
^^ thanks for the help!
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Aug 29, 2018 10:14 AM
WranglerFan
Nov 5, 2017 09:35 AM
RXFEVER
Sep 11, 2016 02:51 PM
airlive
Sep 7, 2015 08:32 PM
