Engine Problem
Old Dec 29, 2007 | 11:09 PM
Spiker's Avatar
Engine Problem
I just got back from a 10 day oversee trip. it was fine when i left it. The first thing i did was put in some more oil, but what i knoticed was that there were alot of foam. After i put in some oil i started the car and there is the check engine light. What do you guys think is the problem?
Old Dec 29, 2007 | 11:15 PM
Redpit10's Avatar
G35 Convert
If your talking about a milky white substance on the dipstick, then this is what you want to read. Mazda will fix it, but supposedly it doesn't cause any problems. As far as the cel, go and get the code pulled free at autozone.
http://www.finishlineperformance.com...0-06-1664A.pdf
Old Dec 30, 2007 | 02:22 AM
Spiker's Avatar
Do you think that is the cause of the enginee light or is something else wrong?
Old Dec 30, 2007 | 06:54 AM
CTrx8's Avatar
space for rent
something else. go to autozone and have the code pulled as redpit mentioned. it will give you a better indicator of what is going on.
check here for CEL codes: https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
Old Dec 30, 2007 | 07:26 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
That's 4................think there is about 25 to go before Winter is done!
Old Dec 30, 2007 | 11:27 PM
whitebeau's Avatar
Touge Chaser
lol Mazurfer make that 5. Mike CEL light came on 2 weeks ago, stumble on startup on one of the rotors until 10 seconds.. then rpm's smooth out.
swapped out the plugs, and got a new battery... it still stumbles for a bit on initial start.. so i'm taking it in, something else is wrong. (Guessing one of the ignition coils).
Let the games begin!
Old Dec 30, 2007 | 11:32 PM
2tone's Avatar
The RX-8 is missed
count me in. i'll be headed to the dealer this week. cel comes on at start-up for a few seconds, then only at highway speeds (68 and up).
xAgyex
Jun 3, 2026 03:47 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
Belalnabi
Jul 17, 2015 07:48 PM
