How to change rotors/brakes
Old Dec 27, 2007 | 05:49 PM
rx8ontheway's Avatar
Exclamation How to change rotors/brakes
IS there any where I can find a step by step on changing the rotors and brake pads myself? Or do you guys think I should let a shop do it... Ive never really messed around on brakes.. but shop is wanting 500$ to install new pads and rotors! THanks for the replies in advance.
Old Dec 27, 2007 | 05:56 PM
dillsrotary's Avatar
jersey fresh
there is a DIY section on this forum ( DIY stands for do it yourself) and there is a step-by-step brake thread in there. I following the thread and it is fairly easy to do.
Old Dec 27, 2007 | 06:05 PM
BlueRenesis82's Avatar
Registered Tracker
Or buy the CD version of the shop manual on ebay. Work it's weight in gold.
Old Dec 27, 2007 | 06:27 PM
altspace's Avatar
Eccentric Shafting
There are also a lot of tricks and techniques when things don't quite move. Would take awhile to writeup everything. Also, you need all the "right" tools.
Old Dec 27, 2007 | 06:46 PM
mysql101's Avatar
you can do it with mostly hand tools. the rear brakes were the only part that forced me to search online here to find out how to compress
Old Dec 27, 2007 | 06:56 PM
staticlag's Avatar
The Professor
Depends on if you trust yourself to fool around with your ability to stop the car.
Old Dec 27, 2007 | 06:59 PM
Brettus's Avatar
Boosted Kiwi
just did this yesterday - 3 hrs to do front rotors + pads all round going at a leisurely pace . $500 sounds like a ripoff .
Old Dec 27, 2007 | 08:59 PM
Registered Tracker
Damn stupid tool that you need. I thought I was going to pop a vessel cranking on that piston pusher-backer-inner
Old Dec 27, 2007 | 09:00 PM
jersey fresh
I used needle nose pliers for the rear, worked fine
Old Dec 27, 2007 | 09:04 PM
mysql101's Avatar
yeah, ended up using pliers
Old Dec 27, 2007 | 09:46 PM
Registered Tracker
I ended up buying the damn thing
airlive
Jun 28, 2020 07:46 AM
mdl0209
May 23, 2019 05:46 PM
Danield97
Sep 30, 2015 05:59 PM
XianUnix
Sep 29, 2015 03:48 PM
