new tires?
Old Dec 26, 2007 | 10:27 PM
tksnobords's Avatar
TK
new tires?
so a month ago i got a new set of rear tires because i had a blowout. now i am getting a new set for the front. is it bad to mismatch tires? any suggestions on tires? i live in the NW and it rains quite a bit here. it doesnt snow muchthough. i want something that will stick when its dry. i dont drive aggressive in the rain...so somethin that holds ok in the rain is fine. i'm thinking about $200ish a tire. what do you guys think...
Old Dec 26, 2007 | 10:35 PM
Gecko69's Avatar
oh boy ...you are going to be flamed.....but why dont you check out www.tirerack.com . Its not bad to mismatch tires, but no the most recommended thing to do.......I guess it depends what you want to do with your car. I would just suggest that you use two of the same tire on the front and rear respectively if you are going to mismatch tires. You should be able to find all the info you need on tirerack.
Old Dec 26, 2007 | 10:55 PM
staticlag's Avatar
The Professor
Its bad to mismatch one tire, it can ruin the differential or screw up your ABS or traction control system.
Old Jan 18, 2008 | 10:05 AM
tksnobords's Avatar
TK
i'm going to match the rear
Old Jan 18, 2008 | 10:14 AM
staticlag's Avatar
The Professor
Should be good for daily drive.
But it will put you at a definite disadvantage if you plan on autox or the track.
Old Jan 18, 2008 | 10:28 AM
Huey52's Avatar
Registered Zoom Zoomer
Goodyear F1's. Primo in the rain. Primo when dry.
http://www.tirerack.com/tires/tires....Eagle+F1+GS-D3
There's an F1 All Season as well.
http://www.tirerack.com/tires/tires....+F1+All+Season
Old Jan 18, 2008 | 10:57 AM
987HYS's Avatar
Dragon Certified
BFG G-Force kdw
Old Jan 18, 2008 | 11:50 AM
connor@tirerack's Avatar
Forum Vendor
Personally i don't recommend mixing tires because it can throw off the traction level from front to back in cold and wet weather. It can also cause vibration issues because of mixing tread designs and compounds. as for the best wet traction i would recommend the following 3 in this order from best to worst.
225/45ZR18 Bridgestone Potenza S-03 -- 125.00
225/45R18 Yokohama ADVAN SPORT -- 205.00
225/45R18 Goodyear Eagle F1 AS -- 162.00
Old Jan 22, 2008 | 10:48 AM
tksnobords's Avatar
TK
cool thanks alot guys.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
