For the occassional trackday: revalved Bilstein HDs w/ tein spring or Bilstein PSS9?
Old Dec 22, 2007 | 12:25 PM
parkpy's Avatar
So I've been mulling over replacement shocks for the RX-8, because I want flat out just want to have a better track setup. I track my car (not autocross) about 5-6x/year. I want to do more trackdays now that I have a reliable car. This is slightly about looks too. I want a lower ride height
My favorite options are:
1) Revalved Bilsteins from FatCatMotorsports with Tein S Tech Springs.
+ I like this option because it's a nearly true off the shelf setup. I don't have time to tinker!
+ Reliable: I loved the Bilstiens. They were covered under warranty, but they never blew out or needed to be replaced over 100,000 miles.
- at $753 for the revalve, $400 for the shocks, and $200 is for the springs, it's a costly expenditure
2) Bilstein PSS9s:
+adjustable ride height
-Progressive spring rates
-not my ideal coilover setup
I'll eventually add sways, if need be. I like the way the car handles now, but I want a little less dive and squat under acceleration, and less body roll. I want a bit better compliance through the rear end too.
Anyways, any advice?
Old Dec 22, 2007 | 12:41 PM
stuntman's Avatar
Professional goofball
PSS9s are great dampers. I also liked the ride of JIC FLT-A2s...
Old Dec 22, 2007 | 06:44 PM
SouthFL's Avatar
Can't go wrong with a Koni + _insert spring here_ setup either.
I'm really happy with my TEIN H-Tech/Koni combo. Been tracking the car every 6 weeks on this setup, retaining stock sway bars and the car is at a perfect compromise between comfort and response.
Anyhow, either option 1 or 2 listed in the original post shall be fine.
Old Dec 28, 2007 | 05:49 PM
AMG-RX7's Avatar
FD owner
Progressive rate springs generally are not necessarily the best choice for a track day car but being able to corner balance the car can be useful on some cars (if you are willing to go with that trouble and expense).
I'm a big Koni + spring fan also. Never had much luck with Bilsteins lasting (especially in colder climates).
Old Dec 31, 2007 | 07:50 AM
CosmosMpower's Avatar
1935 lbs. FTW!
Koni+MS springs or KW V3
jay_tibo
22
Sep 13, 2016 08:10 PM
Paul_Y
Sep 21, 2015 02:23 PM
TotalAutoPerformance
Group Buy Center
Sep 2, 2015 01:40 PM
VS8
Aug 28, 2009 06:15 PM
