Engine Rattle between 3k and 4k rpms
Old Dec 21, 2007 | 04:48 PM
SlotDoc's Avatar
I have a 05 RX8 Manual, during slight acceleration I can hear a faint rattle in the engine between 3k and 4k rpms. I dont think this is the marbles in a can problem, it sounds more like valves knocking. I know the rotary doesnt have valves per say, but I had a honda accord with 300k miles on it with rattling valves and the sounds are very similar. It sounds as if two washers are loose and clanging against one another. After reaching 4k rpm the sound goes away. This happens thru all the gears but much more noticable in 1st thru 4th. Its very faint unless Im driving next to a divider or wall where the sound can bounce back and I can hear it at low speeds. Going to take it to the dealer, just thought I might be able to get some insight on what I could be hearing before presenting the problem to the tech. Last thing I want is a no problem found answer. Any help would be much appreciated.
Old Dec 22, 2007 | 10:47 AM
Railton's Avatar
Check out this thread for rattling noise. Time for a compression check.
Railton
https://www.rx8club.com/series-i-trouble-shooting-95/can-no-longer-maintain-%7E75mph-while-slight-grade-115867/
Old Dec 30, 2007 | 07:06 PM
daisuke's Avatar
rotorized!!!
did you find out what the problem was doc? I'm hearing something similar, the engine almost sounds like a diesel (the sound is very faint as well) altho my rev range seems to be 2.5 to 3.5k rpms
Old Dec 31, 2007 | 01:06 PM
daisuke's Avatar
rotorized!!!
So I took it in to the dealership and after just a few minutes the guy told me that the engine is most likely pinging, to not worry too much about it and use up the gas and then put premium in it.
Old Jan 2, 2008 | 08:31 PM
dazed01's Avatar
Use premium in it, if it does it again call your dealer service dept up and tell them you will come in next time it does it and bring it in HOT so they can do a baro/compression test on it. You will be happy and the tech will be happy.
Old Jul 25, 2008 | 01:08 AM
toneskii707's Avatar
suck my smog
Well did you try it? And did it work? I have the same problem, I put gas in around a little less then half tank so it makes sence, any help would be great
Old Jul 25, 2008 | 07:19 AM
peterlemonjello's Avatar
Take a look at this. If you don't feel any power loss when the noise occurs this is most likely what you're hearing.
https://www.rx8club.com/showthread.p...ghlight=s-dais
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
mdl0209
May 23, 2019 05:46 PM
Mane
Nov 20, 2015 12:16 PM
