turbo xs race pipe
Old Dec 18, 2007 | 11:40 PM
chancejat's Avatar
Drive it like u stole it!
turbo xs race pipe
so i bought a turboxs race only to find out that it doesnt line up on the rear side with stock cat back, so we had to cut the stock piping and turn it 10-15 deg then weld back...........i also bought a ten dollar cel delete off of ebay and so far its working........the midpipe is awesome except for some vibrating at idle.....heres a vid........
http://s246.photobucket.com/albums/g...=Video0010.flv
Old Dec 19, 2007 | 09:29 PM
chancejat's Avatar
damn the cel came on after driving aroud all day........at like 8pm.......i was so happy........damnitt i think i might try the weapon r cel delete bung...........damnit!!!!
Old Dec 19, 2007 | 09:31 PM
chancejat's Avatar
oh yeah the vibrating is getting very annying at stop lights anyone know how to get rid of this?.......... im pretty sure its the muffler........i need to figure out something high temp to pad it
Old Dec 19, 2007 | 09:32 PM
chickenwafer's Avatar
Nope
what is the issue with the rear of the pipe not lining up? Got any pics of the problem?
An no O2 bungs or "spoofing" will work with the RX-8 PCM, not gonna happen
Old Dec 19, 2007 | 09:53 PM
chancejat's Avatar
the turbo xs race pipe was made for the full turboxs system........but it only cost 150.......so i got it......... the holes didnt line up with the stock cat baCK SO WE HAD THE MAKE IT
still would like help finding a solution for the vibrating though anyone?
Old Dec 19, 2007 | 10:05 PM
chetrickerman's Avatar
did you bolt on the springs that were on the stock exhaust. those help the flanges and seals line up correctly
Old Dec 19, 2007 | 10:08 PM
Redpit10's Avatar
G35 Convert
TurboXS midpipe is 3 inches and the stock exhaust is only 2 inches. Thats the begining of your problem. I honestly think that thing will cause you problems until you buy a 3 inch exhaust. As far as a the cel, an O2 simulator could possibly work if your lucky, but most likely it will come back. Our computers on our cars are just too smart for their own damn good.
Old Dec 19, 2007 | 10:09 PM
Nope
No need to get angry, turbo, just asking a simple question.
If you installed the hanger and bolted it all up properly you shouldn't have any vibrations
Old Dec 19, 2007 | 10:10 PM
Nope
Originally Posted by Redpit10
TurboXS midpipe is 3 inches and the stock exhaust is only 2 inches. That the begining of your problem. I honestly think that thing will cause you problems until you buy a 3 inch exhaust.
I've heard this, but the Racing Beat midpipe is also a full 3" pipe that claims to bolt up to the stock catback, so I don't know.
If you can bolt an aftermarket 3" catback to the stock midpipe why can't you bolt an aftermarket 3" midpipe to the stock catback?
Old Dec 19, 2007 | 10:12 PM
i believe there is a reduction in the flanges so it bolts up to the stock exhaust. in order to run the turboXS system good, you need to get the whole thing. midpipe and catback
chancejat's Avatar
i wasnt angry i accidently hit the caps key and was too lazy to change it.......so the vibrating isnt normal, so i should take another looksy at it i guess
Old Dec 19, 2007 | 10:13 PM
VarneyMazda's Avatar
Northeast Pimpin'
i had a similar problem, i used a turbo xs midpipe with a JIC exhaust. I had to modify it to fit. I have a similar rattle that just started happening. just when the car is idling it will vibrate just slightly and we get the "death rattle" as my roomie calls it.
I havent pulled it into the shop to check it. but chances are if u installed it not too long ago maybe a bolt is loose.
Redpit10's Avatar
G35 Convert
I wish I had the answer for you, but I dont. I have the turboXS exhaust, so I read up quite a bit on it, and I kept on seeing people having problems with the turboXS midpipe if they did not buy the exhaust. I guess they might be an exclusive fit type thing.
Old Dec 19, 2007 | 10:14 PM
did you put the springs back on the bolts on the rear flange of the midpipe
Old Dec 19, 2007 | 10:15 PM
it is. TurboXS is the only "Real" 3 in exhaust. all the other ones have reductions so you can use the stock exhaust parts. the turboXS has none except from the exhaust manifold
Old Dec 19, 2007 | 10:17 PM
Redpit10's Avatar
G35 Convert
The vibrating could be from a loose bolt, but I also remeber a bunch of people having problems with that too. I forget, does that midpipe have a hanger? If it does maybe you can bend that downward, cuz I beleive the rattle comes from the midpipe hitting the central brace. So if you bend it downward the midpipe should rise and avoid that rattle. Just my $.02. I ended up selling that midpipe and putting on an RP supercat with my turbo exhaust, so im not real familiar with the midpipe.
Old Dec 19, 2007 | 10:20 PM
chancejat's Avatar
thats sounds plausible..........maybe il try that........i figured out that if i put my foot on anyone of the tips then the rattle stops....
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
arexatemate
Nov 7, 2015 02:27 PM
r-enzyme
Oct 1, 2015 01:27 AM
