View Full Version : Which Tyre shop does Alignment (wf castor measurement)
rx8dorifto
12-17-2007, 09:18 PM
Hi bro,
Anyone know which shop can do good alignment with castor measurement?
Recently changed my spring, the castor a bit off. Did my alignment in a lousy tyre shop which measure the castor using his finger!:Eyecrazy:
After the alignment, still feel my steering a bit weird especially in HDB parking up slope, the steering wont rotate back to center as normal in slow speed. So, I think my castor is really off.
Appreciate if anyone can let me know where can measure the castor angle WITH some sort of device.
Thanks in advanced.
lennon
12-17-2007, 11:04 PM
Check your tyre pressure first b4 do alignment..... Many people doesn't care about this, so does the tyre shop....
lone_wolf025
12-17-2007, 11:17 PM
Any reputable alignment shop can do castor.
rx8dorifto
12-17-2007, 11:18 PM
i did. 230psi all round.
the 1 last thing i can think of is the castor...which normal tyre shop can't measure.:uhh:
sandman369
12-18-2007, 09:32 PM
think most with those electronic alignment sys can measure caster.
try kenny wheel alignment at AMK autopoint 4th floor. call to book appointment before going. 90921015
rx8dorifto
12-19-2007, 01:34 AM
thanks man :)
wildchilde
12-23-2007, 01:39 PM
Or you could try Riverview at AMK autopoint as well. Several peeps I know (not 8 drivers though) go there for alignment.
rx8dorifto
12-23-2007, 08:28 PM
scheduled an appointment with kenny aldy...1 long week wait for the appt!
thanks for all your helps man! I got to keep all these workshop contact in my database.
sandman369
12-23-2007, 10:48 PM
ya it's worth the wait. you should explain your problem and preferences to him, and he should be able to give good advises.
rx8dorifto
12-23-2007, 11:37 PM
yup...found a recommended wheel alignment spec in this forum. But a bit confused, the recommended camber seems too much:
Front Camber: -0`45' (was told that normal camber is -0`20')
Front Toe: -1.1mm
Castor: +6`41'
Rear Camber: -1`44' (isn't this too much for tire wear?)
Rear Toe: +1.7mm (toe out???)
attached with the recommended spec, please let me know that I should follow them.:) thanks
sandman369
12-25-2007, 08:36 PM
Front Toe: -1.1mm
Castor: +6`41'
ok I must first clarify I'm no expert on alignment settings for the 8.
I would normally talk to kenny abt what i want and how i feel so that he can make adjustments. kenny has a few settings for the 8 so you can refer to them. on the figures above, think they look ok. +ve toe means toe-in, so it's ok, slight toe-out in the front and toe-in in the rear (for better turn-in). too much toe can cause tire wear so apply sparingly. the camber settings look ok too. think i'm using -1.5' (ie 1' 30") for the rear. camber settings depends on the vehicle height. with car lowered, think can go until 2' for more agressive settings. for stock, dun go beyond 1'.
rx8dorifto
12-26-2007, 02:39 AM
i got Tein H tech on my ride. But afraid that -1.5' is a bit too much as I dont go track that often.
Think I'll set at -1' first, when going to track then increase it.
