Alignment question
Old Dec 8, 2007 | 11:30 PM
Raptor2k's Avatar
Club Marbles Member
Alignment question
Simple question...should I bother getting an alignment done after putting on a set of Tein S-Techs (already used by a previous owner for about 4k miles) on stock shocks?
Old Dec 8, 2007 | 11:47 PM
romycha1's Avatar
Yes, I didn't.... I have Tanabe's though... And my RR tire is cambered and the tire is wearing unevenly. As of right now, I just need one tire, but who only buys one tire? So I'm having to buy at least two new tires prematurely.... Just spend the extra couple bucks, and get it aligned.
Old Dec 8, 2007 | 11:49 PM
G3tR3DDY2GR3DDY's Avatar
depends what all you took off to put the springs on... if you took off your control arms then you probably didnt get them lined up perfectly again. It obviously wouldnt hurt to get one, but if you removed the control arms i would say to do it.
Old Dec 9, 2007 | 12:20 AM
PhotoMunkey's Avatar
Do the alignment... As you lower the car the front tires toe out. Rear camber and thrust angles also change. You MUST realign it.
Old Dec 9, 2007 | 12:53 AM
x2.
an alignment is cheaper than the damage you are going to do to your tires.
Old Dec 9, 2007 | 01:11 AM
NgoRX8's Avatar
if you don't unbolt any of the control arms, then you will run with slight toe changes that will not affect tire wear as much.
but it's always a good idea to do an alignment.
Old Dec 9, 2007 | 03:33 AM
c41250n's Avatar
you are suppose to!
Old Dec 9, 2007 | 07:34 AM
SouthFL's Avatar
Absolutely, get the car aligned.
Old Dec 9, 2007 | 07:44 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yeah, it's not absolutely needed in every case....but do it anyway.
Old Dec 9, 2007 | 03:34 PM
Raptor2k's Avatar
Club Marbles Member
Alright, thanks. Control arms were unbolted.
Old Dec 9, 2007 | 10:54 PM
nuke0907's Avatar
Never Blend In
i'm also curious about this. i'm gonna have my S-Techs put on tomorrow hopefully. should i wait for them to settle before getting an alignment? how long should i wait before getting it aligned? or, shouldi just get it aligned when i get the springs put on?
Old Dec 9, 2007 | 11:54 PM
If you do the install properly ( ie don't pre-load any of the bushings )
by the time you drive to the alignment shop they will have settled properly.
Otherwise...you could drive it around for a day or so.....to make sure. Won't cause too many problems with that kind of drop
Old Dec 10, 2007 | 09:14 AM
nuke0907's Avatar
Never Blend In
nevermind. my buddy at NAPA is gonna put them on for me and do the alignment for free.
gwailo
May 14, 2024 06:57 AM
nferguson88
Oct 6, 2015 12:45 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
