INT X engine management
Old Dec 7, 2007 | 08:46 PM
olddragger's Avatar
Folks---iI have to give credit to Scott for ---imho-- a really good product. I recently installed the Pettit S.C. kit and used the INT x and a base map Scott installed for it.
The car fired right up, idles well, great power with no hesitations throughout the rpm range. Once I got my vacuum hoses tweaked and the superchargers idle air hose tweaked --the car idles smooth at 1.1K. All functions work well--cruise control, traction control etc. The map is rich so gas mileage sucks right now but that was expected. But with a tune it is expected to be close to oem if not a little better.
The car cranks well even on a 30degree morning.. I didnt have to modify my maf to get an iat sensor. I am just really satisfied.
The flexibility of the unit has convinced me to stay with it instead of an ecm flash that is available. Just for example, i can have a track map ready for when I put the midpipe on, i can have a shift light, i can have a valet map, i can data log til i am sick of it. etc The unit offers a lot--even the ability to tune each rotor separately if it was required.
i am not trying to sell anything to anyone. Just saying that for me the Int X had really lived up to the quality that Mazsport is known for(not to mention the great service that they give)
Now I am fortunate to live in a rather mild climate in comparability to others. i live in GA. So extreme swings in temps/elevations are non existent for me. I do have temps from low 30's to 106 through out the year.
I dont mean to go on and on here but dont discount the INT X as a great EMS for the 8.
When i think well of something i just like to share
oldsuperchargeddragger
Old Dec 7, 2007 | 10:40 PM
rotorocks's Avatar
RotoRocks Powered
It has it's shortcomings, but yeah, Int-X kicks ***, no question about it.
Old Dec 8, 2007 | 12:18 AM
MazdaManiac's Avatar
Originally Posted by olddragger
...the car idles smooth at 1.1K.
??? WTF ???
Old Dec 8, 2007 | 09:04 AM
rotorocks's Avatar
RotoRocks Powered
Originally Posted by MazdaManiac
??? WTF ???
Haven't noticed that.
Yeah, why is that?
Old Dec 8, 2007 | 11:43 AM
morkusyambo's Avatar
Dongbag extrordinare
OD. Could you explain to me how you got the SC to idle consistently. I've been running the map that Scott did for Juan and the only way I can get it to calm down is pump the brake pedal, but that only works untill the next time I come to a stop.
Old Dec 8, 2007 | 07:14 PM
olddragger's Avatar
i had to reroute the jet air hose and the omp vacuum hose back to the intake with the airtake fitting behind the maf. on the install pettit has the omp and the jet air vacuum hoses butted together i also had to install on the supercharger idle air hose a separate air filter(not hooking it to the maf tube) and use a reducer to get the flow right. the idle is controlled more by that hose than anything. After I found the right size reducer--that got the idle to a steady 1.2k---i further tweaked it by placing a clamp on the tube and slowly clamping it until I reached 1.1K. Any lower than that and the idle will wander uncontrollably.
The supercharger has to have an air source at idle--the throttle body is largely closed---right? The supercharger is mounted after the tb--right? so it has to have an idle air cource--now the trick is to "tune" that hose if you will.
Also the other hoses --the jet air in particular needs to function in a more oem way.
Put new plugs in and the above and i have a steady 1.1 idle. I showed this to a bunch of people today including SilverEight etc.
Its rich but I am still getting apprx 225miles per tank. With a tune Scott says i should be back to my usual 280 range.
Tuning the idle for a supercharged engine is a little different than na or turbo. Tuning is more than a/f and timing. Yall probably already know that.
The cold weather start up impressed me.
oscd
Old Dec 8, 2007 | 07:36 PM
Cam is still doing this? I thought they had switched it to the way we were fixing that with the longer MAF tube.
I thought they had fixed that also. That is a real mistake (the way they had it, not the way you fixed it). It puts too much vacuum on the OMP bleed.
This is where you start to scare me.
Its not supposed to be. The idle is supposed to be controlled by the TB.
That is ingenious. Why didn't Pettit think of that...
And this is acceptable to you?
No, not particularly. That's why it has a recirculating bypass.
Yes, but...
No! It should pull the air through the intake, meter it and then recycle it at a 1.5 ratio or so.
Of course.
It shouldn't be. In fact, it should only be A/F and timing since the PCM is still in control of your TB (which is also your functional IAC).
The Int-X always has great start-up - especially when cold. I've noticed that before on all of the Int-setups.
The idle issue is a big problem and one I am interested in seeing addressed by Pettit's flash.
You shouldn't need an idle bleed at all. None of the other Lysholm setups I've seen need one. Did the Millennia S have an idle bleed? I doubt it. Take a look at the system in Corky Bell's "Supercharged". Did it need an idle bleed? No.
If you are happy with this solution than good for you.
Old Dec 9, 2007 | 08:54 AM
olddragger's Avatar
Thanks MM---I am satisfied with the idle at present now. I have always thought the stock idle was too slow for this engine. I know the timing etc swaps around at the oem rate.
A lot of the superchargers use an idle air tube/hose--even idle air motors. Jackson Racing (miata's) for one example. You are right that different set ups can be used.
One thing I havent done yet is to use a good one way valve on that hose. Actually the idle air hose is more of a air balance hose. At idle it just draws a good bit of vacuum.
Curious---how is adding a separate air filter to that hose scare you?
oscd
Old Dec 9, 2007 | 12:32 PM
So have I, but bypassing the throttle isn't the way to do it.
No it doesn't. It has a bypass valve like the Pettit, but it uses a metered IAC valve from the OE Miata setup, not a bleed.
If the '8 had a mechanical idle with a separate bleed, that would be one thing.
But, since it has a PCM controlled TB that acts as an IAC solenoid, bypassing it is not acceptable.
Wanna take a stab at how that works with Pettit's new flash?
oscd
No, using an open-air, un-metered, throttle bypass air bleed scares me.
Old Dec 9, 2007 | 05:30 PM
olddragger's Avatar
sure --unfiltered hose would be bad--I agree.
Jackson has an idle air control hose that is routed to an idle air check valve. Many times miata owners have to use restrict ors on that hose to decrease the amount of air coming in to correct their idle. Different sizes are used until it is correct for that car.
The air coming through the maf doesnt matter in my car because i am running the INT X.
Originally that tube is designed to route to the intake tube. Whether that hose picks its air from the intake tube or through its own filter doesnt matter, The re stricter can be used anywhere the tube is located. I decided to use a separate small filter because i wanted the vacuum source it was using for the jet ait/omp lines as the oem does.
It is just like running some cars with a vacuum leak---the idle goes up or it runs rough--in this case it causes the idle to go up.
As the throttle body is opened the amount of vacuum that hose is pulling is greatly decreased. When you have access to a car with this kit on it --pull the hose off were ever it is running too and then have someone give it the gas while you monitor the vacuum in that hose.
If i leave this hose open and mounted to the air intake then the car idles at about 1.3--1.4 K---tooo fast for me. it is constant--no wandering---but too fast.
Can you explain where the superchargers air supply comes from when the tb is closed? Honest question--no sarcasm meant. It is a draw through system.
I came into this FI world realizing I know little about it
oscd
Old Dec 9, 2007 | 07:57 PM
Bastage's Avatar
DEVILMAN
Hey OD
They got this air-cooled throttlebody thing going now with the Flash. It's pretty badass. Keep the throttlebody cooled!
Old Dec 9, 2007 | 08:00 PM
Bastage's Avatar
DEVILMAN
Originally Posted by Bastage
Hey OD
Hey OD That post about the air-cooled throttlebody in your Int-x thread was total BS btw, I'm just breaking MM's *****. Cam told him about this at SSX and MM got his panties in a bunch. Basically Cam was F'ing with him, but MM didn't know that. So I'm going to keep F'ing with him... hehe
mod edit- this post revived from deletion for clarity- zoom44
Old Dec 9, 2007 | 08:23 PM
They haven't done it that way since the very earliest Sebring kits. I should know. I had an early Jackson and I have another one in a box right in front of me.
Miata's have a cable-pulled throttle, so there is no real consequence from an idle bleed, as long as it doesn't counter the independant IAC, which was removed in the early kits.
right. But it is an issue for the auto foks and those that are NOT going to run the Int-X.
It comes through the throttle body. Its never completely closed.
Even when the car is off, there is a gap in the TB.
The PCM uses the TB as an IAC on the RX-8. This is not a minor point.
Lol! Is that what Cam is calling that now?
Its just a vacuum line re-route. It doesn't cool anything.
It is, however, a nice way to avoid having to use a shaped hose.
That wasn't quite what we were joking about, but Cam and I have a bit of a different understanding than you guys.
Hey - if you were at SSX, why didn't you say hello? Or, are you a ***** like Moon?
Old Dec 9, 2007 | 08:51 PM
Bastage's Avatar
DEVILMAN
It's totally a joke.
I wasn't at SSX, and Moon may be a lot of things, but he's definitely not a *****.
You would have known it if I was at SSX, as I'm definitely not shy with introductions.
Old Dec 9, 2007 | 09:36 PM
Cam didn't start doing that re-route until after SSX. He didn't do it to Jesse's car and Mood added this "function" when he was screwing up a bunch of other things on Phil's car last month. We fixed most of those things back the way they should be, but we left the cooling mod alone because its quite attractive.
The thing that did get my panties in a wad at SSX was the use of a SawzAll on the ABS distribution block bracket on Jesse's car, but I bit my tongue on that one. Wish I hadn't.
Old Dec 9, 2007 | 09:53 PM
Charles R. Hill's Avatar
Owner of BHR
Last month it was Cam that worked on Phil's car.
BTW, who is we?
Old Dec 9, 2007 | 10:05 PM
Cam? I thought Phil said it was Moon.
"We" would be me on the 1st of November and then you.
Old Dec 9, 2007 | 10:19 PM
Owner of BHR
I guess I forgot that when we talked the other day. I probably need to not allow myself to be so distracted on the phone next time. PM me with what ya did so I can keep track of what the Hell has been going on with Phil's car willya? IIRC, Moon may be stopping by to flash Phil's PCM soon.
Old Dec 9, 2007 | 10:24 PM
I thought he was going to do that in February?
I was going to swing by his way on the 22nd. I'll probably still stop by even if it is flashed so I can see what is up.
Old Dec 9, 2007 | 10:28 PM
Owner of BHR
Maybe. I don't care to keep track of Moon's schedule except to the extent that it might involve own toolbag.
I found a simpler, more discreet, way of routing that hose that includes the TB heater circuit but I decided to just leave it as is since it's neither here nor there.
Old Dec 9, 2007 | 11:46 PM
Mechanically, I don't remember if I even fooled with too much under the hood that day.
I just checked to see what changed, shook my head ruefully and off we went into the night with the laptop running full tilt (fed the hamster that night).
I gotta start bringing my little voice recorder with me to sessions so I can keep track of what is going on.
Old Dec 10, 2007 | 12:01 AM
Owner of BHR
I had a stern discussion with Phil about not wanting to play "Ring Around the Rosie" with anybody and, instead, suggested that if any changes are thought to be made to the install I did that I get a call first. The installed "remedy" for the alleged problem was rather "amateurish" in its application. Self-tapping screws tend to have their way with plastic if they don't also include Tinnerman clips. I am no longer hesitant to say that I was disappointed with what I saw last time I was in LV.
Old Dec 10, 2007 | 12:10 AM
I'm not really sure why Cam felt the need to move the coils in the first place, let alone use sheet metal screws.
Did he create any metal shavings for you this time?
I'll give Phil a ring next week and see if it still wants me to come around.
I've still got to figure out what to do with Jesse's system since the OE EMS won't play nice with the idle bleed that OD is so enthusiastic about.
Had a nice discussion with Scott about that subject...
Old Dec 10, 2007 | 12:16 AM
Owner of BHR
The claim, as I understood it, was that the wiring harness was rubbing on the blower housing(?). I am not sure. I could understand the claim, as wrong as it would have been, that the harness was interfering with the A/C pulley. I do know that there was no interference when I did the initial install nor when I left this last time. The coils are secured much better now, as they were beforehand. I can't wait to see what happens over the next few months. I may have some Thank You letters to send.
Old Dec 10, 2007 | 02:20 AM
zoom44's Avatar
no he wont because i specifically asked moon if they had the flash portable in a lap top or something
Originally Posted by Moon Assad
Im taking a trip to MD north on 95 for the holidays and was woundering if anyone would be interested in a install and flash on or near that route. .
i understood it was a "send it in" or come on in flash- when did it go mobile? are you flashing it out of the car ? or thru the diagnostic port? are you travelling with the tool in a laptop?
https://www.rx8club.com/showpost.php...&postcount=778
and he answered
Being mobile with it is going to take longer then expected, sending it in is the only way between now and then. Due to delay on the portable unite.
https://www.rx8club.com/showpost.php...&postcount=779
just in case ill ask him again
