Feed Final gear 4,77 - speedmeter
Old Dec 7, 2007 | 08:40 PM
black-devil's Avatar
Hey guys, i read a lot of posts but i confused. i want to install feed 4.77 and some posts say that the speed sensors need to calibrate and some others that the speed meter shows correct without any modification. Can anyone who install 4.77 answer for sure what happen. Or someone can tell me where speed sensors are located? Thanks and sorry for my poor English
Old Dec 7, 2007 | 08:54 PM
chetrickerman's Avatar
i know that in most cars, the speedo is in the trasmission. but the 8 may be different
i would say PM staticlag or mdw 1000. they both have it
Old Dec 8, 2007 | 01:28 AM
the jury is still out on this.. i have chatted with mdw1000
Old Dec 8, 2007 | 03:22 AM
Brettus's Avatar
Boosted Kiwi
it makes no difference . Speed is measured by the wheel sensors so it does not matter what your diff ratio is - so long as your tyre diameter is same as stock it will read correctly .
Old Dec 8, 2007 | 10:44 AM
staticlag's Avatar
The Professor
Brettus is right, the sensors are in the wheels and therefore gear ratios don't matter. speedometer remains correct as long as you are using the same rolling diameter as stock.
Old Dec 8, 2007 | 08:38 PM
Have you done the change of final gear in your car? Any problems during installation?
Old Dec 8, 2007 | 11:21 PM
staticlag's Avatar
The Professor
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/feed-4-77-review-6mt-126949/
I have it. Its a very difficult installation, at least a 6-9 hour teardown/rebuild for an experienced mechanic. I wouldn't recommend it for a DIY. Namely because the bearings need to be pressed on the gear in order to work and most people don't have access to a hydraulic press. So you could do it with a piece of pipe and a hammer and a lot of elbow grease but a lot of things could go wrong that would leave you running out to buy new tools or seals.
On a scale of 1-10, changing the gears on a mustang or other American muscle car = 3-4
changing the gears on this car = 10
Old Dec 17, 2007 | 05:54 PM
I made the change and everything is OK. About the old one (4,44) final gear, in which cars fit so i can sell it?
Old Dec 17, 2007 | 07:43 PM
LSD and gears are interchangable for manual trans FD3 RX-7 TT and the RX-8 cars
Old Dec 17, 2007 | 08:08 PM
Is it possible to fit to a miata or honda s2000?
Old Oct 31, 2012 | 10:46 AM
longpath's Avatar
Does the odometer derive inputs the same way?
Old Oct 31, 2012 | 03:17 PM
Bladecutter's Avatar
Rockie Mountain Newbie
Nice bump.
But yes, the speedo and odometer are based off of wheel speed sensors.
BC.
Old Oct 31, 2012 | 04:57 PM
as stated, if you changed tire diameter from OE it will be off some
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
dezau
RX-8 Racing
10
Mar 9, 2016 09:50 AM
Racingjunkie
Sep 29, 2015 05:05 PM
pjwermuth
Sep 28, 2015 11:36 PM
