tein h-tech, how close is it to stock?
Old Dec 7, 2007 | 02:54 PM
raizen82's Avatar
resist, un-learn, defy...
anyone with this set of spring? i'm planning on getting the tein h-tech just to get rid of the wheel gap without having a suspension that is too stiff or uncomfortable for daily driving. is it very close to the stock feel?
Old Dec 7, 2007 | 03:05 PM
Spinning Sushi's Avatar
I <3 Sushi
H-Techs are designed with a luxury ride in mind. It should be very comfortable with an aggressive look to it. Some people think they're more comfortable then stock.
Old Dec 7, 2007 | 03:11 PM
raizen82's Avatar
thanks, how about the tanabe NFs?
Old Dec 7, 2007 | 03:12 PM
bruce_van's Avatar
Bruce Van
If you want a good drop and want to keep the stock feel, look into the Tanabe NF springs.
I went with the Tein-S techs, but think they are a little too stiff for me since I would rather have a more comfortable ride than a sportier ride.
If I were to do it again, I'd probably go with the Tanabes.
Old Dec 7, 2007 | 03:31 PM
raizen82's Avatar
which would be better overall then, tein H tech or the tanabe NF?
Old Dec 7, 2007 | 03:40 PM
BigRed's Avatar
w8nkel
^well what do you want out of them?
Old Dec 7, 2007 | 03:46 PM
raizen82's Avatar
lowered look but most comfortable ride. i don't mind if the h-tech doesn't drop much. comfort is priority lol
Old Dec 7, 2007 | 05:23 PM
raizen82's Avatar
and is it true that the tanabe NF might shorten the life of my stock shocks?
Old Dec 7, 2007 | 05:41 PM
AK83's Avatar
Arrow Re:
Same could be said for the H-Techs, just not as fast as the Tanabes. Anytime you get stiffer springs than stock, the struts will wear out quicker, how much quicker depends on how much stiffer the new springs are.
Old Dec 7, 2007 | 05:45 PM
NgoRX8's Avatar
the tanabe's lower more, especially in the rear. giving more chance of hitting the bumpstop upon rebound.
Old Dec 7, 2007 | 05:57 PM
raizen82's Avatar
^yep, that's what i'm concerned about, too. roads here aren't very smooth aside from the many bumps.
Old Dec 7, 2007 | 06:01 PM
SouthFL's Avatar
I think the H-Tech is the best compromise between comfort and performance. I use them paired with Koni dampers for my street/track car and I'm very impressed with the comfort, yet the car performs very well.
Old Dec 7, 2007 | 07:37 PM
raizen82's Avatar
good point. when i save enough and it's time to change shocks then i can get the koni. btw, can you give me the link to the koni product? i always see koni but i don't know the exact name of the product/model etc. thanks
Old Dec 7, 2007 | 07:58 PM
rglbegl's Avatar
Baned
If you are looking to get rid of the wheels gap, get the s-techs. They are almost the same spring rate as the stock, but about an inch lower. (there have been MANY discussions here about spring rates, so lets not start that arguemet in this thread) I have seen h-techs on an RX8, and it looked completely stock. If you want to look stock, with a stock ride . . . . get stock springs. If you want to look a little lower, get the s-techs
Old Dec 7, 2007 | 11:30 PM
SouthFL's Avatar
I would argue that the H-Tech does lower the car enough so that it is noticeable (if that's something you value). It's not a slammed look, but there is a sportier stance. Definately not stock looking IMO.
Old Dec 8, 2007 | 03:26 AM
raizen82's Avatar
ok, i just found out that the eibach pro springs have almost the same stiffness as the tien h-techs plus it gives a little more noticeable drop. i'll probably get the eibach pro kit instead. just gotta find a good quote on this.
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
XianUnix
Sep 29, 2015 03:48 PM
GK1707
Sep 27, 2015 07:33 PM
