airbag codes
Old Dec 6, 2007 | 10:19 PM
RotaryResurrection's Avatar
kevin@rotaryresurrection
airbag codes
Can anyone here tell me what airbag code 33 (3 flashes, pause, 3 flashes, repeat) relates to?
My car had been in a light front end wreck prior to me getting it. I have replaced both front airbags and the front crash sensor and still have this code. I have reset the SAS module by unplugging it for several minutes and still get the code/light immediately upon startup.
I have verified that the airbags I installed are making good connection by unplugging them one by one and observing new codes pop up. Using this method, I have found a few of the other codes, perhaps these will help someone in the future:
driver seat, 5-1
passenger seat, 5-2
passenger dash, 2-1
driver steering wheel, 1-9
front crash sensor, 4-2
And no, I dont want to 'take it to the dealer". I have no desire to spend hours waiting and pay hundreds of dollars for "diagnostics" to tell me what a simple code represents. I have access to pretty much any part I might need used (non wreck car) if I can just find out what to buy.
If it comes down to it and I can't fix this simply, I guess a piece of black tape will go on the instrument cluster face.
Any help is appreciated.
Old Dec 11, 2007 | 12:28 PM
secret8gent's Avatar
the enemy in the mirror
B1877 33
13 Driver-side pre-tensioner seat belt circuit resistance high (See DTC B1877, B1878, B1879, B1885.)
B1878 Driver-side pre-tensioner seat belt circuit short to power supply
B1879 Driver-side pre-tensioner seat belt circuit short to body ground
Old Dec 11, 2007 | 12:34 PM
for you
grab a copy of this (I'll only leave it up for a little while...)
Old Dec 11, 2007 | 01:47 PM
HOLY **** MAN, THANK YOU!!
That is awesome. Now I know what to buy and replace without ripping the whole car up. I will save those pdf's along with the FSM that I have for future reference.
Remind me the next batch of chrome rotors I put up for sale and I will give you one a little cheaper.
Old Dec 11, 2007 | 02:57 PM
you are welcome!
Old Apr 19, 2012 | 04:35 AM
lardyboy's Avatar
@secret8gent
Hi - I had a little accident in my 8 the other day and could do with any help how to reset the airbags so the car will start again.. any chance of them pdf's please?
Old Jan 23, 2022 | 05:11 AM
Rx8new's Avatar
MY air bag light flashes 4 times then 2 times and does this about twice till the light remains on solionCan I have a look at the pdfs?
Old Jan 25, 2022 | 07:36 AM
it’s unlikely that anyone will reply from 15 years ago.
I can probably generate a new set and attach them properly to the thread for future retrieval. Send me a pm reminder if I don’t get to it in the next several days.
Old Jan 10, 2023 | 03:29 PM
auzoom's Avatar
Hmmmmmm.........
Reminder :D
Old Jan 12, 2023 | 02:22 PM
he couldn’t follow directions to send me a pm either
Old Jan 12, 2023 | 02:37 PM
Old Jan 18, 2023 | 03:22 PM
auzoom's Avatar
Hmmmmmm.........
Thank you. I was going to send you one but you posted them
Old Jan 18, 2023 | 03:27 PM
auzoom's Avatar
Hmmmmmm.........
Does anyone know if the codes related to say "drivers side" translate between LHD and RHD? I am assuming drivers side means drivers side not RHD drivers side but figured I would check.
Im getting the 22 with B1994 - Drivers side circuit resistance high.
Old Jan 19, 2023 | 01:18 PM
The codes posted above are from a USDM service manual, so this means LHD for drivers side. That’s all I can really tell you without ever seeing a manual for a RHD car.
Shankapotamus3
Mar 14, 2021 03:53 PM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
tommy26Germany
Sep 29, 2015 10:33 AM
