maximum flow of NA rx-8
Old Dec 6, 2007 | 08:21 PM
tajabaho1's Avatar
Destroying Threads
ok, for the sake of the argument, lets say with an NA rx8, everything functioning optimally (rarely the case in real life)
what is the maximum diameter of the throttle body, manifold and air intake to achieve the most whp?
same goes for exhaust.
what is the stats for our exhaust port? which I think RG or someone said is the real restrictor?
Old Dec 6, 2007 | 10:18 PM
chickenwafer's Avatar
Nope
Doesn't matter until the engine flows more, the exhaust ports are restrictive but there isn't a whole lot that can be done.
Old Dec 6, 2007 | 10:32 PM
MazdaManiac's Avatar
At standard temperature and pressure (and assuming a 90% Ve at 9200 RPM), a naturally aspirated Renesis will move 28 pounds of air a minute at 383 CFM.
Old Dec 6, 2007 | 10:42 PM
mac11's Avatar
Rotary , eh?
Technically the MAXIMUM would be ~420cfm/~32lbs/min but thats 100%VE 9200RPM. The number MM posted with 90%VE is closer to the truth.
Old Dec 6, 2007 | 10:47 PM
tajabaho1's Avatar
Destroying Threads
ok, thankyou for the info, just wanted to know some figs
Old Dec 6, 2007 | 10:50 PM
Nope
Be honest, Taj, you have no idea how to digest the numbers you just saw
Old Dec 6, 2007 | 10:52 PM
Well, yeah.
Actual airflow measurements say its 90% Ve at that RPM.
Old Dec 6, 2007 | 10:54 PM
eviltwinkie's Avatar
Originally Posted by MazdaManiac
Well, DUH.
fixed...
Old Dec 6, 2007 | 10:59 PM
mac11's Avatar
Rotary , eh?
Well, yeah.
I was pretty sure I was agreeing with you
Old Dec 6, 2007 | 11:00 PM
Yes. Yes you were. Sorta.
I'm pretty sure he doesn't even understand the question.
Old Dec 6, 2007 | 11:10 PM
tajabaho1's Avatar
Destroying Threads
what was the question? what is the answer? I have no clue, who posted the damn question?
Old Dec 7, 2007 | 11:30 AM
zoom44's Avatar
well there are rpms when the flow is actually above 100% ve.
Old Dec 7, 2007 | 11:37 AM
zoom44's Avatar
https://www.rx8club.com/showthread.p...highlight=flow
is where the pertinent info can be found
following that graph you can work out that at 9200 rpm the VE is actually 87% or what jeff posted in his rotary math thread
Old Dec 7, 2007 | 11:41 AM
mac11's Avatar
Rotary , eh?
Right, but its not at a high enough RPM to be flowing more than 32lbs/min.
Old Dec 7, 2007 | 11:45 AM
Taj; why do you even want to know?
Old Dec 7, 2007 | 11:57 AM
zoom44's Avatar
sure its about 26.5 ilbs/min at 7k. but i thought it would be good to bring it up anyway- at the least it will confuse taj which should prove humorous and at most he might learn something
Old Dec 7, 2007 | 12:03 PM
mac11's Avatar
Rotary , eh?
sure but i thought it would be good to bring it up anyway- at the least it will confuse taj which should prove humorous and at most he might learn something
Thanks for posting that chart, BTW. I had completely lost track of it and was using blind theoretical VE numbers for everything recently.
Old Dec 7, 2007 | 09:33 PM
thecow135's Avatar
um, i like chicken.
Old Dec 7, 2007 | 09:53 PM
636's Avatar
636
Rice Police
^^ i prefer to eat cows. But yes , chicken is good too.
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
9krpmrx8
Oct 13, 2015 01:36 PM
Tsurugi
Sep 7, 2015 08:27 PM
Rupanrx
Sep 4, 2015 06:44 AM
