**FS: 2 10' Infinity Kappas w/ Alpine Amp in BASSWORDX sealed box**
Old Dec 6, 2007 | 07:59 PM
stinky's Avatar
Gas Drinker.
2 10 inch Infinity Kappa Perfect 10.1s in a SEALED BASSWORX Box.
Alpine MRP-M450 Amplified attached to the side. This is from the 2006 lineup from Alpine.
All this stuff is basically in new condition.! Less than a year old.
Alpine MRP M450 Specs
CEA-2006 Power Rating
CEA-2006 Power Rating (40hm@14.4V = 1%THD+N), S/N 65dBA (Ref. 1W into 4Ohm): 220W x 1
RMS Power (at 14.4V THD+N, 20Hz-20kHz)
Per channel into 4 ohms: 220W x 1 (0.08% THD)
Per channel into 2 ohms: 400W x 1
Infinity Kappa Perfect 10.1 Specs
Details:
* 10" 4-ohm subwoofer
* aluminum cone with high-roll butyl-rubber surround
* massive cast-aluminum basket
* suitable for free-air use (handles up to 175 watts in free-air applications)
* recommended power range: 75-350 watts RMS
* peak power handling: 1,400 watts
* frequency response: 18-200 Hz
* sensitivity: 94 dB
* top mount depth: 5-3/4"
* sealed box volume: 0.6 cu. ft.
* ported box volume: 1.0 cu. ft.
Dont want to part.
Came out of my RX8. So for those with small trunks, this is perfect.
Again, 2 10 inch infinity kappa perfects in a sealed bassworx box with an alpine mrp m450 amp mounted on its side.
**ASKING 380 CDN OBO**
(Im located in vancouver, bc)
Please email lvs888@hotmail.com if interested.
Can deliver within a reasonable distance.
I an deliver as far as WASHINGTON/OREGON for a fee.
Attached Thumbnails **FS: 2 10' Infinity Kappas w/ Alpine Amp in BASSWORDX sealed box**-sa1.jpg   **FS: 2 10' Infinity Kappas w/ Alpine Amp in BASSWORDX sealed box**-sa2.jpg   **FS: 2 10' Infinity Kappas w/ Alpine Amp in BASSWORDX sealed box**-sa4.jpg   **FS: 2 10' Infinity Kappas w/ Alpine Amp in BASSWORDX sealed box**-sa5.jpg
Old Dec 6, 2007 | 08:03 PM
G3tR3DDY2GR3DDY's Avatar
wow those kappas are nice- is that box custom fit for the eight or does it have gaps on the sides? and how far does it stick out past the dropdown? would you split the amp from the speakers/box combo??
Old Dec 6, 2007 | 08:35 PM
stinky's Avatar
Gas Drinker.
it fits right in that gap in the rear trunk. it does not stick out past the tire well.
which means you have lots of trunk space left!
and i will only part if everything is sold at once.
Learners_Permit
Sep 27, 2015 07:38 PM
LPCOKIE
Jan 5, 2009 06:19 PM
Juice
Feb 2, 2008 01:10 PM
Mort
Sep 24, 2007 05:55 AM
BomberNYC
Dec 31, 2005 12:08 PM
