MT-90 in the differential
Old Dec 2, 2007 | 06:52 PM
aznboyga's Avatar
I had some Redline MT-90 lying around and need to change the differential fluid. I'm probably going to use RP 75w-90 but just curious what would be the side effects of using the Redline.
Old Dec 2, 2007 | 08:00 PM
Jasonawojo's Avatar
AFAIK, the MT-90 is only for Manual Transmissions, and it doesn't have the LSD additives that your differential needs. Redline makes a GF-5 gear oil ("75w90 Gear Oil"), specifically for limited slip differentials. Shouldn't be any issues with that or RP Max Gear 75w90.
Old Dec 3, 2007 | 12:24 PM
the moment you put MT-90 into your Rear Diff, its the moment your Diff getting its slow and painful death.
Warrior777
Jun 24, 2019 04:47 PM
reni04
Aug 21, 2015 01:52 PM
reni04
Aug 21, 2015 01:33 PM
Jaguar_MBA
Dec 2, 2005 09:36 AM
